Re: BOG OFF THE LINE
[Re: rickb67]
#1245694
06/05/12 01:50 AM
06/05/12 01:50 AM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: Cab_Burge]
#1245701
06/05/12 05:27 PM
06/05/12 05:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The needles and seast shouldn't affect the intitial hit, but they could
HIGHLY unlikely... there should be plenty of volume in the bowls even with the stock .110 N/S for coming off the line... cheapest thing to try is the jet extensions (race car should have them anyways)... then squirters
[Re: Irun5snd8th]
#1245702
06/05/12 05:34 PM
06/05/12 05:34 PM
MR_P_BODY
It either needs one of two things, both meaning more fuel. Jet extensions or increase the fuel pressure from the pump to the regulator and from run as much fuel pressure from the regulator to the carb as you can without pushing past the floats. Somewhere near nine pounds is usually where the floats give up. Had this exact issue on alchol and it was the fuel pressure from the pump to the regulator. Minimum 23 lbs. Give it a shot and let us know.
Better recalibrate your gauge... even Holley will tell you 7.5 is on the edge... when I use to flow fuel pumps at work 7.5 was the max allowed pressure
[Re: rickb67]
#1245704
06/05/12 10:09 PM
06/05/12 10:09 PM
MR_P_BODY
IT IS A E85 CARB I HAD A GUY CONVERT IT IN DENVER. I SHOULD HAVE ALREADY HAD EXTENSIONS IN THE CARB. THAT WILL BE FIRST THING I DO THAT AND INCREASE FUEL PRESSURE TO 7 FROM 6 LBS. IN TWO WEEKS A BUDDY IS DRIVING THE CAR AND I WILL BE WRENCHING. SO WILL SEE. THANKS GUYS
What kind of altitude did you run before and now... it can be dog lean
