Page 4 of 10 1 2 3 4 5 6 9 10
Re: Return of ALTERKATION fued [Re: Daniel Niclas] #1244338
06/15/12 12:26 PM
06/15/12 12:26 PM
B-Body Bull Offline
B-Body Bull  Offline
Yee Haw ! I'm just gonna weld in one of these http://www.howeracing.com/p-7861-rt-road-race.aspx cuz that that thar stock torsion bar crap ain't gonna cut it. Who wants a car that was engineered to drive on public roads ? No torsion bars in race cars ? http://pitstopusa.com/c-133297-sprint-car-parts-torsion-bars-arms-stops-torsion-bars.html Might as well just weld in a GM metric front stub cuz they win all the races at my local track, and they are STOCK !
Re: Return of ALTERKATION fued [Re: B-Body Bull] #1244339
06/15/12 12:34 PM
06/15/12 12:34 PM
Milford, IL
68Plymouths Offline
68Plymouths  Offline
Milford, IL
Yep, and here is the rear suspension for a sprint car, try it in your street car, baby...
http://www.spitzracing.com/index_files/Page724.htm
Re: Return of ALTERKATION fued [Re: 68Plymouths] #1244340
06/15/12 03:45 PM
06/15/12 03:45 PM
Santa Fe Springs, CA
Dan@Hotchkis Offline
I've added a jam nut, so there will be some deflection in the bushing, but I don't anticipate it will roll much.
I'd look into a secondary way to stabilize that LCA from rotating. A jam nut and that strut may not be enough for extended use. I would also be inclined to think that after the suspension cycles a few thousand times, that jam nut may find its way loose. That said however, as far as race car suspensions, I like what you did there.
Re: Return of ALTERKATION fued [Re: Dan@Hotchkis] #1244341
06/15/12 06:23 PM
06/15/12 06:23 PM
Milford, IL
68Plymouths Offline
68Plymouths  Offline
Milford, IL
Thanks for the suggestion. The suspension is going to have to be maintained at regular intervals because the heims are going to have to be cleaned and lubed. I'll be sure to check the jam nut and keep an eye on the lca rotating. Also, the lower coil-over mount helps to keep it from rotating.
Re: Return of ALTERKATION fued [Re: 68Plymouths] #1244342
06/15/12 10:15 PM
06/15/12 10:15 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Sure looks pretty.
How high are your roll centers lining up to be?
Did you maintain the stock camber gain percentage or change that for more/less?
Re: Return of ALTERKATION fued [Re: Kern Dog] #1244343
06/16/12 04:42 AM
06/16/12 04:42 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I only have one question.... What's a fued ? I don't have a Phd.. Is it a new language? I work with quite a few folks with Phd's, I have a brother & a sister with Phd's... I wouldn't say they all have perfect spelling, but I will say I've never seen such an obvious misspelling posted on an open forum by any of them...
FWIW I read most of the first post & I've read most of this post... I haven't seen folks saying anything negative about the Altercation stuff, I've seen people question the need or if there is any real gain but I don't see that as negative yet I see a number of posts slamming the OE stuff & torsion bars... The only people in a "Feud" appear to be the Altercation supporters...
Re: Return of ALTERKATION fued [Re: 1_WILD_RT] #1244344
06/16/12 07:10 AM
06/16/12 07:10 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
This is Part Deux. You missed the original thread that got deleted.
Re: Return of ALTERKATION fued [Re: slantzilla] #1244345
06/16/12 12:41 PM
06/16/12 12:41 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
No, I did not miss the first thread... The majority of people saying something if flawed are the Altercation supporters sayin the stock stuff doesn't work well....
Re: Return of ALTERKATION fued [Re: 1_WILD_RT] #1244346
06/16/12 01:00 PM
06/16/12 01:00 PM
I think if it is one thing that has been proven, the faster/fastest cars out there are cars using the stock based components. At out last Auto cross event, The fastest car was our Challenger on 200 TW tires, and I was fourth in the Road Runner, also on 200 TW tires. The two cars that beat me were 1st gen Camaros, both with full C6 vette underpinnings, and one of them was on R-Comps. Both the Challenger and I never did a run without passengers. The field was pretty varied, had new muscle from the big three, an 09 ACR Viper, and plenty of older muscle.
I think that the only black eye given to my/our record was at the 2011 OUSCI, since the Road Runner was completely unprepared for that event, but I still beat out both the other Mopars there overall in points.
That said, our cars, on leafs and torsion bars are still more capable than most other cars. At our track days, The Road Runner has no issues keeping up with Spectre's Carbon Camaro, and many of our other cars. I'll be tearing the car down a bit next month, for more tire, more motor and less spring/more sway bar in the front as well as seeing if we can get the trans shifting a bit better (high speed down shifts are no bueno right now).
Re: Return of ALTERKATION fued [Re: Dan@Hotchkis] #1244347
06/16/12 02:16 PM
06/16/12 02:16 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
... less spring/more sway bar in the front ...
That's what I do with my AMX, works for me. Also did it with my '71 Plymouth Sebring way back in the '70s, worked great on the street also, soft ride and took the corners great. Even handled the 1/4 mile oval at midnight one race weekend. The guys I was on their pit crew said I did better with my street car then the 'stock' race cars did, even tho I was the only car out there.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Return of ALTERKATION fued [Re: slantzilla] #1244348
06/16/12 03:48 PM
06/16/12 03:48 PM
Chicago, Illinois
Devil Online penguin-006
Devil  Online Penguin-006
Chicago, Illinois
It was not deleted. It was moved to the tech archives.
https://board.moparts.org/ubbthreads/show...e=0&fpart=1
Ryan
Re: Return of ALTERKATION fued [Re: Dan@Hotchkis] #1244349
06/16/12 08:53 PM
06/16/12 08:53 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Track times and speeds are quantifiable measurements that cannot lie........
Re: Return of ALTERKATION fued [Re: PHJ426] #1244350
06/20/12 11:54 AM
06/20/12 11:54 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I've said it before and I'll say it again; IMO, While they may provide some improvements in geometry the biggest gain in "feel" that most aftermarket suspensions provide is because knowledgeable engineering types are specifying spring and shock rates that better achieve a more neuteral balance to the roll percentages than what most laymen can put together themselves. This, in turn, is interpreted as a superior package over the stock longitudal layout. While they are typically incrementally better, they usually are not quantum leap better. The exception possibly being the bent bar set ups, which were a pooch right out of the gate.
Re: Return of ALTERKATION fued [Re: TC@HP2] #1244351
06/20/12 12:15 PM
06/20/12 12:15 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Worth saying again, but if you could make it sound "cooler", they just might start to listen, but probably not.
Re: Return of ALTERKATION fued [Re: jcc] #1244352
06/24/12 10:54 PM
06/24/12 10:54 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
That's why I built my own crap... No one to blame but me....
Re: Return of ALTERKATION fued [Re: Dos Snails] #1244353
06/24/12 10:58 PM
06/24/12 10:58 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
Re: Return of ALTERKATION fued [Re: Dos Snails] #1244354
06/24/12 11:04 PM
06/24/12 11:04 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
So what are we looking at, are those c7 spindles?
Re: Return of ALTERKATION fued [Re: jcc] #1244355
06/24/12 11:10 PM
06/24/12 11:10 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
Corvette C5/C6 stuff... It all started when Xv did not want to just sell me their K member. So I have about $700 in it & alot of time learning..
Re: Return of ALTERKATION fued [Re: Dos Snails] #1244356
06/24/12 11:13 PM
06/24/12 11:13 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Can you "attach" the printouts for easier reading?
Looks neat
Re: Return of ALTERKATION fued [Re: jcc] #1244357
06/24/12 11:25 PM
06/24/12 11:25 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
I don't have it on my hard drive but will transfer it though..
