727 Governor selection ? #1242801
05/31/12 01:41 PM
05/31/12 01:41 PM
florida/ Georgia
Tom Fox Offline OP
Tom Fox  Offline OP
florida/ Georgia
O.K. Building A 727, Using The Best/Heaviest Duty Parts From My Stash Of Cores.Is There A BEST Governor To Look For To Obtain A Higher Shift Point In W.O.T?
Re: 727 Governor selection ? [Re: Tom Fox] #1242802
05/31/12 05:33 PM
05/31/12 05:33 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Depends on how high you want the shift point. It is possible to get a combination of governor parts that won't allow a shift before the engine's rpm limit..AMHIK.
Re: 727 Governor selection ? [Re: Tom Fox] #1242803
05/31/12 09:31 PM
05/31/12 09:31 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
How high of a shift point are you looking for? A&A's governors have always worked well for me. Although there is usually a split between the 1-2 and the 2-3 shifts.
Master, again and still
Re: 727 Governor selection ? [Re: Tom Fox] #1242804
05/31/12 09:46 PM
05/31/12 09:46 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've had good success drilling the inner weight .375" dia .375" deep. I take about .200 off the outer weight leaving the original diameter about .100" from each end. This has resulted in 5600-5900 shift. Not rocket science but it has worked.
Doug
Re: 727 Governor selection ? [Re: Tom Fox] #1242805
05/31/12 09:57 PM
05/31/12 09:57 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The hp governor from the late 60s is a good starting point IMO. With near std line pressure, it should shift around 5200 to 5400. Then by drilling the inner weight you can get that governor to shift up to about 5800 to 6000 without messing with the springs. You'll then need to play with the 1-2 shift spring, more than likely, to get the 1-2 and 2-3 shift where you want them both.
Re: 727 Governor selection ? [Re: dvw] #1242806
05/31/12 10:11 PM
05/31/12 10:11 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Doug
dvw, that is about what I got too: 3/8" dia. x 3/8" deep....starting with a hp governor shift about 5800 w/ slightly increased line pressure too.
Re: 727 Governor selection ? [Re: DaveRS23] #1242807
05/31/12 10:30 PM
05/31/12 10:30 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
If you get the governor set up where you like it using modified stock pieces or buying A&A pieces,and the two shift points don't match,call Rick at A&A. He can set you up with a 1-2 shift valve spring to bring it up to match the 2-3 shift or the other way around.
Keith
Re: 727 Governor selection ? [Re: Dunnuck Racing] #1242808
05/31/12 11:22 PM
05/31/12 11:22 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
That is a good place to start, but there is about 600 to 800 rpm difference between Rick's two springs. They are probably perfect for some applications, but I ended up buying a half dozen springs to get what I needed for mine.
Re: 727 Governor selection ? [Re: BSB67] #1242809
06/01/12 06:31 AM
06/01/12 06:31 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
That is a good place to start, but there is about 600 to 800 rpm difference between Rick's two springs. They are probably perfect for some applications, but I ended up buying a half dozen springs to get what I needed for mine. [/quote
I agree that my method had different shift rpm for the 1/2 and the 2/3 with the stock spring. Where did you get all the different springs?
Doug
Re: 727 Governor selection ? [Re: dvw] #1242810
06/01/12 07:09 AM
06/01/12 07:09 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Doug
http://www.leespring.com/
Re: 727 Governor selection ? [Re: BSB67] #1242811
06/01/12 11:48 AM
06/01/12 11:48 AM
dogdays Offline
dogdays  Offline
Dodge Colt governor? does that ring any bells?
R.
Re: 727 Governor selection ? [Re: BSB67] #1242812
06/01/12 08:36 PM
06/01/12 08:36 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I usually set the 2-3 lower than the 1-2 shift and adjust the governor to shift the 1-2 where I want it. That way I can launch with the selector in 2 and not have to concern myself with that quick shift. Then there is plenty of time to manual the 2-3 higher than the auto shift point that is probably too low.
I have not had any luck with A&A's split shift springs getting the 2 shift points close enough to work for me.
Re: 727 Governor selection ? [Re: DaveRS23] #1242813
06/01/12 10:19 PM
06/01/12 10:19 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I have done that same thing in the past. This time I set it up to have both gear changes automatic. So with that I set the governor to shift 2-3 where I wanted and changed the 1-2 shift spring to tune that shift point.
