Re: 727 Governor selection ?
[Re: Tom Fox]
#1242802
05/31/12 05:33 PM
05/31/12 05:33 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Depends on how high you want the shift point. It is possible to get a combination of governor parts that won't allow a shift before the engine's rpm limit..AMHIK.
[Re: Tom Fox]
#1242803
05/31/12 09:31 PM
05/31/12 09:31 PM
Posts: 12,160 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
How high of a shift point are you looking for? A&A's governors have always worked well for me. Although there is usually a split between the 1-2 and the 2-3 shifts.
Master, again and still
[Re: Tom Fox]
#1242804
05/31/12 09:46 PM
05/31/12 09:46 PM
Posts: 9,853 MI, usa
dvw
MI, usa
O.K. Building A 727, Using The Best/Heaviest Duty Parts From My Stash Of Cores.Is There A BEST Governor To Look For To Obtain A Higher Shift Point In W.O.T?
I've had good success drilling the inner weight .375" dia .375" deep. I take about .200 off the outer weight leaving the original diameter about .100" from each end. This has resulted in 5600-5900 shift. Not rocket science but it has worked. Doug
[Re: dvw]
#1242806
05/31/12 10:11 PM
05/31/12 10:11 PM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
dvw, that is about what I got too: 3/8" dia. x 3/8" deep....starting with a hp governor shift about 5800 w/ slightly increased line pressure too.
[Re: BSB67]
#1242809
06/01/12 06:31 AM
06/01/12 06:31 AM
dvw
MI, usa
That is a good place to start, but there is about 600 to 800 rpm difference between Rick's two springs. They are probably perfect for some applications, but I ended up buying a half dozen springs to get what I needed for mine. [/quote
I agree that my method had different shift rpm for the 1/2 and the 2/3 with the stock spring. Where did you get all the different springs? Doug
[Re: dvw]
#1242810
06/01/12 07:09 AM
06/01/12 07:09 AM
BSB67
Prospect, PA
http://www.leespring.com/
[Re: BSB67]
#1242812
06/01/12 08:36 PM
06/01/12 08:36 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I usually set the 2-3 lower than the 1-2 shift and adjust the governor to shift the 1-2 where I want it. That way I can launch with the selector in 2 and not have to concern myself with that quick shift. Then there is plenty of time to manual the 2-3 higher than the auto shift point that is probably too low. I have not had any luck with A&A's split shift springs getting the 2 shift points close enough to work for me.
