a500 shift changes #1241819
05/29/12 05:53 PM
05/29/12 05:53 PM
norway
aufles.mopar Offline OP
norway
hi
what parts should i change in my a500 transmission to get it change gears earlyer.i put a a500 transmission from a 1990 dodge van into my 33 plymouth.it changes to late.
anyone know?could i take some parts from a a904 transmission passenger car?
1971 cuda and 1934 plymouth hotrod
Re: a500 shift changes [Re: aufles.mopar] #1241820
05/29/12 10:05 PM
05/29/12 10:05 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
How do you have the kick-down linkage adjusted? Ease up on the kick-down lever a little and it'll lower the line, in return bringing the shift points at slower speed.
Re: a500 shift changes [Re: MarkZ] #1241821
05/30/12 01:59 PM
05/30/12 01:59 PM
norway
norway
hi
i use lokar kit that is adjusted correct.i have tryed to remove it too,but it is the same.
Re: a500 shift changes [Re: aufles.mopar] #1241822
05/30/12 04:13 PM
05/30/12 04:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Are you saying with the Lokar disconnected it still shifts late?
With no linkage or cable and the transmission lever full forward it should shift way early.
Re: a500 shift changes [Re: John_Kunkel] #1241823
05/30/12 06:39 PM
05/30/12 06:39 PM
IL
furious70 Offline
furious70  Offline
IL
what speeds/rpms are you seeing your shifts?
70 Sport Fury
68 Charger
69 Coronet
72 RR
