a500 shift changes
#1241819
05/29/12 05:53 PM
05/29/12 05:53 PM
Posts: 34 norway
aufles.mopar
norway
hi what parts should i change in my a500 transmission to get it change gears earlyer.i put a a500 transmission from a 1990 dodge van into my 33 plymouth.it changes to late. anyone know?could i take some parts from a a904 transmission passenger car?
1971 cuda and 1934 plymouth hotrod
Re: a500 shift changes
[Re: aufles.mopar]
#1241820
05/29/12 10:05 PM
05/29/12 10:05 PM
Posts: 4,441 Michigan
MarkZ
Worthy
Worthy
How do you have the kick-down linkage adjusted? Ease up on the kick-down lever a little and it'll lower the line, in return bringing the shift points at slower speed.
[Re: MarkZ]
#1241821
05/30/12 01:59 PM
05/30/12 01:59 PM
Posts: 34 norway
aufles.mopar
norway
hi i use lokar kit that is adjusted correct.i have tryed to remove it too,but it is the same.
[Re: aufles.mopar]
#1241822
05/30/12 04:13 PM
05/30/12 04:13 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Are you saying with the Lokar disconnected it still shifts late?
With no linkage or cable and the transmission lever full forward it should shift way early.
[Re: John_Kunkel]
#1241823
05/30/12 06:39 PM
05/30/12 06:39 PM
Posts: 2,255 IL
furious70
IL
what speeds/rpms are you seeing your shifts?
70 Sport Fury 68 Charger 69 Coronet 72 RR
