Re: 5 prong relay
[Re: ks66]
#123985
09/21/08 07:57 PM
09/21/08 07:57 PM
Posts: 3,407 S.E. Florida, USA
rrunner
S.E. Florida, USA
This may be electrical 101, but I need help. How do you wire in a 5 prong relay for a fuel pump? The pump and battery are in the trunk w/battery cut-off switch. I would like to operate the pump with a switch on the dash. The prongs are numbered 30,85,86,87,&87a. Does the wire from the switch to the relay require a power source? Thanks for any and all help.
30 is battery hot at all times, 87 & 87a are to what you are powering, fuel pump in your case so just use 87 as you only needed a four pin, 85 & 86 are the coil you can either use a switched power or ground it doesn't matter. If you need any other help with this pm me and I will send you my phone #
