This may be electrical 101, but I need help. How do you wire in a 5 prong relay for a fuel pump? The pump and battery are in the trunk w/battery cut-off switch. I would like to operate the pump with a switch on the dash. The prongs are numbered 30,85,86,87,&87a. Does the wire from the switch to the relay require a power source? Thanks for any and all help.
