OIL SLINGER ON A 440??? #1239231
05/24/12 10:54 PM
05/24/12 10:54 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Do I have to use one on my 440? What are the PRO'S and CON'S? Thanks in advance! Randy
Re: OIL SLINGER ON A 440??? [Re: Labratt] #1239232
05/24/12 11:40 PM
05/24/12 11:40 PM
Amherst,NY
challengermike Offline
Amherst,NY
I have been leaving them off and havnt had any problems or leaks.
Re: OIL SLINGER ON A 440??? [Re: Labratt] #1239233
05/24/12 11:49 PM
05/24/12 11:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
New engines dont have them... they were used back
in the day to help cover up IFFY seals... plus run
a 100K miles... I havent used one in years with the
better quality seals now days
Re: OIL SLINGER ON A 440??? [Re: Labratt] #1239234
05/25/12 09:08 AM
05/25/12 09:08 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Will some please make this question a sticky once and for all?
Along with "What is the best rear main seal?" and
"Where can I find a BB oil pump gasket?"....
Re: OIL SLINGER ON A 440??? [Re: Commando1] #1239235
05/25/12 09:13 AM
05/25/12 09:13 AM
tboomer Online work
tboomer  Online Work
Why the negative vibes?? If you don't like a thread,don't look at it...Sure...A lot of questions are asked over and over...And not everyone catches them. Get over it already!!
Re: OIL SLINGER ON A 440??? [Re: Commando1] #1239236
05/25/12 09:19 AM
05/25/12 09:19 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
All anybody needs to do is send me a PM for the answers to all three questions
BTW Randy, I've never used a slinger in any of mine
the seal is more than adequate
Re: OIL SLINGER ON A 440??? [Re: roadhazard] #1239237
05/25/12 09:50 AM
05/25/12 09:50 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
No slinger here either. If it's main purpose is to prevent leaks from lousy seals, slinger is a misleading name because that makes it sound like its job is to distribute oil.
If it was called a blockade, and many people dont use it but aren't leaking oil out the front, it would be more obvious that it's not needed
Re: OIL SLINGER ON A 440??? [Re: Exit1965] #1239238
05/25/12 09:54 AM
05/25/12 09:54 AM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
I wondered the same thing when I did my old motor. I bought one and was told it wasn't necessary. I had no problems with leaks.
Randy
Re: OIL SLINGER ON A 440??? [Re: Dartin] #1239239
05/25/12 10:09 AM
05/25/12 10:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah the term is misleading... never could see how
it would sling oil up onto the chain... you would think
it would have had some sort of paddles at the ends
to throw oil around
Re: OIL SLINGER ON A 440??? [Re: Labratt] #1239240
05/25/12 11:40 AM
05/25/12 11:40 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Its job was to sling oil OFF the crank snout. Using a slinger with a Neoprene seal can lead to a grooved damper hub. You want some oil on one side of the seal to lube it.
Re: OIL SLINGER ON A 440??? [Re: @#$%&*!] #1239241
05/25/12 01:05 PM
05/25/12 01:05 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Looks like the "Slinger" stays in the parts drawer in the future! Thanks guys! Randy
Re: OIL SLINGER ON A 440??? [Re: tboomer] #1239242
05/26/12 09:56 AM
05/26/12 09:56 AM
Commando1 Offline
Commando1  Offline
I strongly suggest you get over it and think twice before flapping your pie hole.
No negative vibes were intended in that comment.
It was a legitimate request to the mods because a certain few questions do get asked so often.
Re: OIL SLINGER ON A 440??? [Re: Commando1] #1239243
05/26/12 10:28 AM
05/26/12 10:28 AM
tboomer Online work
tboomer  Online Work
How dare you!! Many questions are repeatedly asked and yet everyone in this forum does the best they can to answer!! How much have you contributed? Looks like not a lot to me!! And flapping my piehole...You have no respect whatsoever... I hope you have a nice holiday vacation!!
