Turn signals, but no brake lights #1234435
05/16/12 02:04 PM
05/16/12 02:04 PM
San Angelo, Texas, U.S.A.
1968RR Offline OP
1968RR  Offline OP
I'm trying to get my '68 Roadrunner up to par for inspection, and my turn signals are working, but not my brake lights. I've checked and made sure that I've got continuity for both filaments in each of the bulbs. I only want to take apart my steering column to check the turn-signal switch as a last resort. Any connections I should check? Anyone have a wiring schematic for a '68 Plymouth?
Thanks in advance for any help.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Turn signals, but no brake lights [Re: 1968RR] #1234436
05/16/12 02:10 PM
05/16/12 02:10 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
How about the simple thing like do you have power in and out of the brake light switch to the turn signal switch? If you do then the problem is going to be the ts switch. The same wires feed from the switch to the rear lights for ts and brake lights. If you have rear signals then the wiring is good from the switch to the lights.
Re: Turn signals, but no brake lights [Re: stumpy] #1234437
05/16/12 02:45 PM
05/16/12 02:45 PM
Andrewh Offline
Andrewh  Offline
simple things first.
do you have dash lights?
if not could the fuse be burned out?
has happened to me. looked good, but was actually bad.
Re: Turn signals, but no brake lights [Re: Andrewh] #1234438
05/16/12 02:47 PM
05/16/12 02:47 PM
1968RR Offline OP
1968RR  Offline OP
I checked the voltage across the wires going to the brake light switch and it was low/zero (0.03 V). I'll check and make sure that the fuses are good. Anything else to check for?
Re: Turn signals, but no brake lights [Re: 1968RR] #1234439
05/16/12 03:04 PM
05/16/12 03:04 PM
1968RR Offline OP
1968RR  Offline OP
Fuse is blown...should've checked it first-thing. Thanks for the help.
