Turn signals, but no brake lights
#1234435
05/16/12 02:04 PM
05/16/12 02:04 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I'm trying to get my '68 Roadrunner up to par for inspection, and my turn signals are working, but not my brake lights. I've checked and made sure that I've got continuity for both filaments in each of the bulbs. I only want to take apart my steering column to check the turn-signal switch as a last resort. Any connections I should check? Anyone have a wiring schematic for a '68 Plymouth? Thanks in advance for any help.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Turn signals, but no brake lights
[Re: Andrewh]
#1234438
05/16/12 02:47 PM
05/16/12 02:47 PM
1968RR
I checked the voltage across the wires going to the brake light switch and it was low/zero (0.03 V). I'll check and make sure that the fuses are good. Anything else to check for?
[Re: 1968RR]
#1234439
05/16/12 03:04 PM
05/16/12 03:04 PM
1968RR
Fuse is blown...should've checked it first-thing. Thanks for the help.
