Did I screw up?? Main/Rod clearance question..
#1233725
05/15/12 01:00 PM
05/15/12 01:00 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
To avoid hijacking the other post, I'm starting this one for a little clarification help..
I'm currently in the middle of a 572, max effort, race only build.. Before dropping the parts off at the machine shop, I was confident in the bearing clearance of between .025-.030..
The machinist agreed with my spec's and did his thing on the new World block.. After picking up the parts, we measured the clearances for both the rod and the mains.. and they came in at .035 instead of the .024-.026 the machinist claimed on the build sheet..
Since the machinist missed a couple things on the block and since the clearances wasnt where we agreed, the machinist took the block back to finish it and I'm supposed to get the call today to come and pick it up..
In the other thread, there seems to be a consensus that the Rods/Mains should be anywhere from .030 -.050 for a big block, aluminum rod, race only motor..
So my question is.. Did I screw up by asking for .025 clearance??
Re: Did I screw up?? Main/Rod clearance question..
[Re: Jeepmon]
#1233727
05/15/12 01:07 PM
05/15/12 01:07 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I helped George finish up a fairly big N.M.R.A. motor and he actually set em up a bit tighter like .0025-.003 iirc which is where they were at teardown and at 3800lbs. it went 8.05 in Vegas..........your call.
[Re: 10sec440]
#1233731
05/15/12 02:50 PM
05/15/12 02:50 PM
Jeepmon
Sunnyvale, CA
Just for clarity thats .0028"-.0030" right? If you have .030" clearance you're in big trouble!
Yeah.. you're correct.. shoot, I'm just an electrician and our tolerance is 18".. give or take an inch or two..
[Re: Jeepmon]
#1233732
05/15/12 02:56 PM
05/15/12 02:56 PM
Guitar Jones
That's what she said...
[Re: Guitar Jones]
#1233733
05/15/12 04:08 PM
05/15/12 04:08 PM
Posts: 2,560 S.E. Michigan
cl440
S.E. Michigan
Tree'd.....LOL
[Re: Jeepmon]
#1233734
05/15/12 04:25 PM
05/15/12 04:25 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm sure you mean .0025 to .003 Treed also
