Did I screw up?? Main/Rod clearance question.. #1233725
05/15/12 01:00 PM
05/15/12 01:00 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
To avoid hijacking the other post, I'm starting this one for a little clarification help..
I'm currently in the middle of a 572, max effort, race only build.. Before dropping the parts off at the machine shop, I was confident in the bearing clearance of between .025-.030..
The machinist agreed with my spec's and did his thing on the new World block.. After picking up the parts, we measured the clearances for both the rod and the mains.. and they came in at .035 instead of the .024-.026 the machinist claimed on the build sheet..
Since the machinist missed a couple things on the block and since the clearances wasnt where we agreed, the machinist took the block back to finish it and I'm supposed to get the call today to come and pick it up..
In the other thread, there seems to be a consensus that the Rods/Mains should be anywhere from .030 -.050 for a big block, aluminum rod, race only motor..
So my question is.. Did I screw up by asking for .025 clearance??
Re: Did I screw up?? Main/Rod clearance question.. [Re: Jeepmon] #1233726
05/15/12 01:04 PM
05/15/12 01:04 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
Yes, you did!
If you divide this clearance by 10 you have a better chance not getting "knocked"
Re: Did I screw up?? Main/Rod clearance question.. [Re: Jeepmon] #1233727
05/15/12 01:07 PM
05/15/12 01:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I helped George finish up a fairly big N.M.R.A. motor and he actually set em up a bit tighter like .0025-.003 iirc which is where they were at teardown and at 3800lbs. it went 8.05 in Vegas..........your call.
Re: Did I screw up?? Main/Rod clearance question.. [Re: Thumperdart] #1233728
05/15/12 02:38 PM
05/15/12 02:38 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thanks guys..
Just got off the phone with the machinist.. He told me the clearance is set between .028 and .031..
Re: Did I screw up?? Main/Rod clearance question.. [Re: Jeepmon] #1233729
05/15/12 02:40 PM
05/15/12 02:40 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thanks guys..
As Dram would say, " You`re golden"............
Re: Did I screw up?? Main/Rod clearance question.. [Re: Thumperdart] #1233730
05/15/12 02:46 PM
05/15/12 02:46 PM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
Just for clarity thats .0028"-.0030" right? If you have .030" clearance you're in big trouble!
Re: Did I screw up?? Main/Rod clearance question.. [Re: 10sec440] #1233731
05/15/12 02:50 PM
05/15/12 02:50 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Yeah.. you're correct.. shoot, I'm just an electrician and our tolerance is 18".. give or take an inch or two..
Re: Did I screw up?? Main/Rod clearance question.. [Re: Jeepmon] #1233732
05/15/12 02:56 PM
05/15/12 02:56 PM
Guitar Jones Offline
That's what she said...
Re: Did I screw up?? Main/Rod clearance question.. [Re: Guitar Jones] #1233733
05/15/12 04:08 PM
05/15/12 04:08 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Tree'd.....LOL
Re: Did I screw up?? Main/Rod clearance question.. [Re: Jeepmon] #1233734
05/15/12 04:25 PM
05/15/12 04:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm sure you mean .0025 to .003
Treed also
Re: Did I screw up?? Main/Rod clearance question.. [Re: Jeepmon] #1233735
05/15/12 04:30 PM
05/15/12 04:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Didnt those rods have a clearance on the box... I
dont remember
Re: Did I screw up?? Main/Rod clearance question.. [Re: Jeepmon] #1233736
05/15/12 09:45 PM
05/15/12 09:45 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Thats what she said LOL
I have run several engine with more than .003 and never had any trouble...
Id rather have them a half thou loose than tight....
