Re: engine plate this right!
[Re: Dodgem]
#1232241
05/12/12 06:54 PM
05/12/12 06:54 PM
Posts: 5,619 long island NY
Ari440
long island NY
I would put the heads and headers on first , see where it sits and take it from there
1.39 9.85 - 137 mph
[Re: Cab_Burge]
#1232248
05/13/12 01:30 AM
05/13/12 01:30 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I like mine back a little more than that As already said, stick the heads, valve covers and headers on and go from there
?? maybe i'll stick the drive shaft in and see if I can move it back 1/4 to 1/2". since I went ladder bars may have an little wiggle room!
motor front to back should be right where it always has been as tranny mount has not moved and cross member and mount are right back where they belong!
Thanks guys! had moroso solid mounts before think they are close to 1/4 higher than stock thins should fit better but i'll slide the oil pan up there!
[Re: Dodgem]
#1232249
05/13/12 01:34 AM
05/13/12 01:34 AM
Posts: 43,275 Bend,OR USA
Cab_Burge
