engine plate this right! #1232239
05/12/12 06:44 PM
05/12/12 06:44 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
so the tranny is mounted up as always and plate is sitting on the frame so if this is rignt I can weld and bolt the brackets into place??
Thanks in advance.
Re: engine plate this right! [Re: Dodgem] #1232240
05/12/12 06:50 PM
05/12/12 06:50 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
looks good to me,
Re: engine plate this right! [Re: Dodgem] #1232241
05/12/12 06:54 PM
05/12/12 06:54 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
I would put the heads and headers on first , see where it sits and take it from there
1.39 9.85 - 137 mph
Re: engine plate this right! [Re: Dodgem] #1232242
05/12/12 06:55 PM
05/12/12 06:55 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
x2 checking with headers ...measure 10 times, weld once.
Re: engine plate this right! [Re: Dodgem] #1232243
05/12/12 07:08 PM
05/12/12 07:08 PM
fresno ca
mikeysmopars Offline
fresno ca
mine is mounted the same way
Founder and CEO of the Central Valley Mopar Drag Pack
Re: engine plate this right! [Re: Ari440] #1232244
05/12/12 08:25 PM
05/12/12 08:25 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
Andy Fs plate should be right on the money.
Re: engine plate this right! [Re: Dodgem] #1232245
05/12/12 08:32 PM
05/12/12 08:32 PM
I like mine back a little more than that As already said, stick the heads, valve covers and headers on and go from there
Re: engine plate this right! [Re: Cab_Burge] #1232246
05/12/12 10:05 PM
05/12/12 10:05 PM
Howell,MI
Moparpoor Offline
Moparpoor  Offline
Howell,MI
Check the oil pan clearances.I have had to shim up the plate a 1/4 or so due to oil pan and chassis variations.As for any other fitment issues none.Andy F builds quality pieces!!!
Re: engine plate this right! [Re: Moparpoor] #1232247
05/12/12 10:29 PM
05/12/12 10:29 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
Yes - check the heads, valve covers and headers before locking it down.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: engine plate this right! [Re: Cab_Burge] #1232248
05/13/12 01:30 AM
05/13/12 01:30 AM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
?? maybe i'll stick the drive shaft in and see if I can move it back 1/4 to 1/2". since I went ladder bars may have an little wiggle room!
motor front to back should be right where it always has been as tranny mount has not moved and cross member and mount are right back where they belong!
Thanks guys! had moroso solid mounts before think they are close to 1/4 higher than stock thins should fit better but i'll slide the oil pan up there!
Re: engine plate this right! [Re: Dodgem] #1232249
05/13/12 01:34 AM
05/13/12 01:34 AM
I moved my motor back about one inch, I elongated the trans mount so I could slide the trans back until it almost hit the mount on the tailshaft housing I can get the passenger side valve cover off with the heater in the car with a low deck motor, not so with a high deck motor No driving in the winter with no heater, defroster or traction
Re: engine plate this right! [Re: Cab_Burge] #1232250
05/14/12 07:32 PM
05/14/12 07:32 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Thanks cab I moved it back about .150 from where it was rear end must have got moved back when ladder bars where installed?? Think we needed some tire clearance at the front so drive shaft was out more that I would like!
This will also give me a little more wiggle room at the front between the electric fan and electric water pump it was close and the motor plate is .100 wider than the old water pump spacers for the gear drive.
Thanks again guys!
