how much gear lube??? #1230565
05/09/12 07:28 PM
05/09/12 07:28 PM
western Ky
CraigS Offline OP
CraigS  Offline OP
western Ky
How much gear lube in my moser60 dana axle?I am changing it ,and i cant remember how much goes in.The fill plug seems awful high up on the cover to fill it up yhat high,but i cant get ahold of moser and wondered if someone on moparts hac a moser 60 ????I think I put in 3 quarts ,but that was 2 years ago.Thanks guys
Re: how much gear lube??? [Re: CraigS] #1230566
05/09/12 09:38 PM
05/09/12 09:38 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
My Dana with an Ultimate 60 cover takes about a gallon.I don't use the level plug though it seems pretty high.I have a large filler plug so I can see when it's a little under the axle centerline
Gus
64 Plymouth Savoy
Dana 60
Re: how much gear lube??? [Re: fourgearsavoy] #1230567
05/09/12 09:48 PM
05/09/12 09:48 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I run 2 1/2 qt with my Dana with an Ultimate 60 cover. you can put alot more in there. if you drive it on the street you might run more. Now a aftermarket housing might be diff.
Re: how much gear lube??? [Re: VernMotor] #1230568
05/09/12 10:24 PM
05/09/12 10:24 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
2.5 qts. is what we run
Re: how much gear lube??? [Re: CraigS] #1230569
05/09/12 10:59 PM
05/09/12 10:59 PM
Cab_Burge Online work
Cab_Burge  Online Work
I think the factory service manuals says the capacity is 5 pints Years ago when Direct Connection was sponsoring the drag seminars the Mopar drag race engineers recommended using only one quart of gear lube in both the Dana 60 and 8 3/4, they said the rest of the fluids in them where for noise contaiment only I run a spool in my Dana 60 in my (limited) street (less than 500 miles a year on the street) and strip Duster, 80 runs last year. I filled the Dana 60 up to the filler plug, over three quarts, two years ago, I drain it this past winter and put half that amount back in, no troubles so far after 15 passes
Re: how much gear lube??? [Re: Cab_Burge] #1230570
05/09/12 11:52 PM
05/09/12 11:52 PM
western Ky
CraigS Offline OP
CraigS  Offline OP
western Ky
Thanks Guys .2 and a half sounds about right for me.
Re: how much gear lube??? [Re: CraigS] #1230571
05/09/12 11:56 PM
05/09/12 11:56 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
What type of gear fluid do you use?
Any difference with a locker??
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: how much gear lube??? [Re: Kam*Kuda] #1230572
05/10/12 05:33 PM
05/10/12 05:33 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
A locker with no clutchs in it. just what ever gear oil you run I am running a spool with 90-140 synthetic. now clutchs need additive
Re: how much gear lube??? [Re: CraigS] #1230573
05/11/12 09:40 AM
05/11/12 09:40 AM
an8sec70cuda Offline
2 to 2.5 quarts.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: how much gear lube??? [Re: VernMotor] #1230574
05/11/12 12:13 PM
05/11/12 12:13 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Slightly off topic, but I have synthetic lube in my 9.25" axle, factory clutch LSD. I've read on various forums that with synthetic lube you don't need the additive because of how slippery the synthetic stuff is. I have no clutch chatter and my unit works great, is it safe to assume that I'm ok without the additive then?
**Photobucket sucks**
