Re: how much gear lube???
[Re: CraigS]
#1230569
05/09/12 10:59 PM
05/09/12 10:59 PM
Posts: 43,311 Bend,OR USA
Cab_Burge
I think the factory service manuals says the capacity is 5 pints ![](/ubbthreads/images/graemlins/shruggy.gif) Years ago when Direct Connection was sponsoring the drag seminars the Mopar drag race engineers recommended using only one quart of gear lube in both the Dana 60 and 8 3/4, they said the rest of the fluids in them where for noise contaiment only ![](/ubbthreads/images/graemlins/scope.gif) I run a spool in my Dana 60 in my (limited) street (less than 500 miles a year on the street) and strip Duster, 80 runs last year. I filled the Dana 60 up to the filler plug, over three quarts, two years ago, I drain it this past winter and put half that amount back in, no troubles so far after 15 passes ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: CraigS]
#1230571
05/09/12 11:56 PM
05/09/12 11:56 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
What type of gear fluid do you use?
Any difference with a locker??
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: CraigS]
#1230573
05/11/12 09:40 AM
05/11/12 09:40 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
