8.750/dana question #1229276
05/08/12 01:55 AM
05/08/12 01:55 AM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
0k got a severe case of CRS, cannot for the life of me remember,,,are the axel splines the same for both rear's?
Re: 8.750/dana question [Re: dartman366] #1229277
05/08/12 01:59 AM
05/08/12 01:59 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes I believe they are
Re: 8.750/dana question [Re: MR_P_BODY] #1229278
05/08/12 02:10 AM
05/08/12 02:10 AM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
thanks Mike,,I have a guy at work that is having a heck of a time finding a good 8.750 posi unit for his,,,,now get this,,,a 1952 chevy street rod, it came with a 8.750 in it,he has found a Dana with a good posi and 4.10 gears and wants to have his axels fit to the dana, he plans on buying the green bearings and new tube ends and have a local fab shop do the work, I think it's a neet idea, if I could only talk him into a nice 440.
Re: 8.750/dana question [Re: dartman366] #1229279
05/08/12 06:54 AM
05/08/12 06:54 AM
Guitar Jones Offline
8.75 came factory with 30 splines, some Dana's did also but there are also 35 spline Dana's. The housing ends are the same if the Dana was a passenger car rear.
Re: 8.750/dana question [Re: dartman366] #1229280
05/08/12 10:10 AM
05/08/12 10:10 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What year is the Dana and is it a truck or car rear? 68-69 car rear is 23 spline , 70-72 car rear is 35 spline , I think that some truck rears were 16 spline .
He needs to pull an axle on that dana and find out what it is before , plus 8.75 axles are same lenght side to side , danas aren't.
Re: 8.750/dana question [Re: JohnRR] #1229281
05/08/12 10:51 AM
05/08/12 10:51 AM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
I will have him pull an axel to make sure and yes it came from a mid 80's 3/4 ton dodge van.
Re: 8.750/dana question [Re: dartman366] #1229282
05/08/12 11:19 AM
05/08/12 11:19 AM
an8sec70cuda Offline
That dana probably has 23 spline axles. I thought 8 3/4 rears had 30 spline axles?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 8.750/dana question [Re: an8sec70cuda] #1229283
05/08/12 11:26 AM
05/08/12 11:26 AM
I had a sure grip or trac loc from a mid 80's van and it had 30 splines.
Re: 8.750/dana question [Re: Guitar Jones] #1229284
05/08/12 11:45 AM
05/08/12 11:45 AM
I'm pretty sure the 8 3/4 originally in my cuda was 30 spline.
Both Dana 60's I've worked w/ recently were both 23 spline and from mid '70s trucks.
CHIP
Re: 8.750/dana question [Re: an8sec70cuda] #1229285
05/08/12 12:55 PM
05/08/12 12:55 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
8.75 should have 30 spline through all years.
D60 can have 16, 23, 30 or 35 splines and maybe some more stuff in between.
The 30 splines for each rear are the same diameter.
Re: 8.750/dana question [Re: RobX4406] #1229286
05/08/12 01:12 PM
05/08/12 01:12 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
I know that the 8.750 is 30 spline, but did not realize the dana's had so many variations of spline count,,,learn somthing every day.
thanks for the responses guy's.
Re: 8.750/dana question [Re: dartman366] #1229287
05/08/12 02:50 PM
05/08/12 02:50 PM
Cab_Burge Online work
Cab_Burge  Online Work
1970 GMC and Chevy trucks came with 30 spline Dana 60 I'm almost sure some of the 3/4 ton vans ,Ford, Mopar and GM came with them also, mayybe not You can change the side gears in the non 30 spline posi to 30 spline side gears
