8.750/dana question
#1229276
05/08/12 01:55 AM
05/08/12 01:55 AM
dartman366
Mt. Vernon, Ohio
0k got a severe case of CRS, cannot for the life of me remember,,,are the axel splines the same for both rear's?
Re: 8.750/dana question
[Re: MR_P_BODY]
#1229278
05/08/12 02:10 AM
05/08/12 02:10 AM
dartman366
Mt. Vernon, Ohio
thanks Mike,,I have a guy at work that is having a heck of a time finding a good 8.750 posi unit for his,,,,now get this,,,a 1952 chevy street rod, it came with a 8.750 in it,he has found a Dana with a good posi and 4.10 gears and wants to have his axels fit to the dana, he plans on buying the green bearings and new tube ends and have a local fab shop do the work, I think it's a neet idea, if I could only talk him into a nice 440.
[Re: dartman366]
#1229279
05/08/12 06:54 AM
05/08/12 06:54 AM
Guitar Jones
8.75 came factory with 30 splines, some Dana's did also but there are also 35 spline Dana's. The housing ends are the same if the Dana was a passenger car rear.
[Re: dartman366]
#1229280
05/08/12 10:10 AM
05/08/12 10:10 AM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
What year is the Dana and is it a truck or car rear? 68-69 car rear is 23 spline , 70-72 car rear is 35 spline , I think that some truck rears were 16 spline .
He needs to pull an axle on that dana and find out what it is before , plus 8.75 axles are same lenght side to side , danas aren't.
[Re: dartman366]
#1229282
05/08/12 11:19 AM
05/08/12 11:19 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
That dana probably has 23 spline axles. I thought 8 3/4 rears had 30 spline axles?
[Re: an8sec70cuda]
#1229283
05/08/12 11:26 AM
05/08/12 11:26 AM
Guitar Jones
I had a sure grip or trac loc from a mid 80's van and it had 30 splines.
[Re: Guitar Jones]
#1229284
05/08/12 11:45 AM
05/08/12 11:45 AM
an8sec70cuda
I'm pretty sure the 8 3/4 originally in my cuda was 30 spline.
Both Dana 60's I've worked w/ recently were both 23 spline and from mid '70s trucks.
[Re: RobX4406]
#1229286
05/08/12 01:12 PM
05/08/12 01:12 PM
dartman366
Mt. Vernon, Ohio
I know that the 8.750 is 30 spline, but did not realize the dana's had so many variations of spline count,,,learn somthing every day. thanks for the responses guy's.
[Re: dartman366]
#1229287
05/08/12 02:50 PM
05/08/12 02:50 PM
Posts: 43,198 Bend,OR USA
Cab_Burge
1970 GMC and Chevy trucks came with 30 spline Dana 60 I'm almost sure some of the 3/4 ton vans ,Ford, Mopar and GM came with them also, mayybe not You can change the side gears in the non 30 spline posi to 30 spline side gears
