Carb info #1227669
05/05/12 06:02 PM
05/05/12 06:02 PM
Dearborn Hts, MI
Sledge_57 Offline OP
Dearborn Hts, MI
My friend has a 70 Road Runner, 383, 4 speed, 4 barrel.
He wants to find the proper carb for this engine and I told him I'd ask the experts. He has a build sheet (mostly legible) if needed. He's also wondering if there was some sort of spacer or a certain gasket used for the carb. He says it has some sort of metal gasket at the moment.
So... anyone?
Thanks...
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: Carb info [Re: Sledge_57] #1227670
05/05/12 06:07 PM
05/05/12 06:07 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
Holley 4367 unless it is an N95 emissions car or a fresh air equipped car. Is it either or both of those? If so, it will use a different Holley 4bbl. Is the CARB section of his broadcast sheet legible? It is located in the top third of the sheet.
Re: Carb info [Re: m46rat] #1227671
05/05/12 06:21 PM
05/05/12 06:21 PM
Dearborn Hts, MI
Dearborn Hts, MI
He says it has a Carter at the moment, so it definitely should be a Holley in 1970?
What exactly do we need to look for on the broadcast sheet, I assume it's not clearly spelled out....
Doug
Re: Carb info [Re: Sledge_57] #1227672
05/05/12 06:28 PM
05/05/12 06:28 PM
m46rat Offline
m46rat  Offline
It IS clearly spelled out! Fourth line down from the top, there are two numbers listed under CARB. That would be three boxes in from the left side of the sheet. What are the two numbers?
Re: Carb info [Re: m46rat] #1227673
05/08/12 07:53 PM
05/08/12 07:53 PM
Dearborn Hts, MI
Dearborn Hts, MI
OK he finally found his sheet. The CARB code is 36.
Doug
Re: Carb info [Re: Sledge_57] #1227674
05/08/12 08:42 PM
05/08/12 08:42 PM
m46rat Offline
m46rat  Offline
The carb. service number that corresponds to that is 3418 536 which is for a Holley 4367 4bbl carb. If he really wants a correct one, you will need to find out the SPD(Scheduled Production Date) of the car. It is located under Vehicle Production Number at the top of the broadcast sheet. It is the first three digits on the left.
Then find a 4367 dated previous to that date. I may have one, or Scott Smith at Harms Auto may also. Let me know what the three digits are.
Re: Carb info [Re: m46rat] #1227675
05/09/12 01:32 AM
05/09/12 01:32 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I'm watching, post the date and I'll check
Re: Carb info [Re: ScottSmith_Harms] #1227676
05/10/12 02:39 PM
05/10/12 02:39 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I have a 3039 dated (Thursday, 10/30/69) Holley 4367 that I won't be using.
Re: Carb info [Re: 6bblgt] #1227677
05/10/12 08:23 PM
05/10/12 08:23 PM
MoreParts Offline
MoreParts  Offline
Just to piggy back on this thread with a quickie of a question. I have a 70 Challenger R/T with a scheduled date of 5/15/70 and the holley carb (4368) has a date 71 days prior. Would that be considered in the realm of acceptable build dates?
Re: Carb info [Re: MoreParts] #1227678
05/10/12 08:55 PM
05/10/12 08:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What is the assembly date on the engine ?
that asked , the engine was stamped with an assembly date before being painted and the carb was installed after paint ... I ASSuME ... so it should still be AROUND the assembly , but more than likely BEFORE ...
Scoot and others probably have a better idea.
Oh and don't go looking to dan for a price on that carb , he's a few hundred HIGH on his pricing ...
Re: Carb info [Re: JohnRR] #1227679
05/10/12 09:07 PM
05/10/12 09:07 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
i already SOLD that carb anyway..so good luck.. got 250.00 for mine.. dan
Re: Carb info [Re: JohnRR] #1227680
05/10/12 10:02 PM
05/10/12 10:02 PM
MoreParts Offline
MoreParts  Offline
It's been a heck of a long time since I've checked those codes. I've had the car since '91. Where would it be on a 383 car?
Re: Carb info [Re: ph23vo] #1227681
05/10/12 10:37 PM
05/10/12 10:37 PM
New Mexico
JMCFAN Online content
JMCFAN  Online Content
New Mexico
dang! you did good!
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
