Fuel pressure problem -- FOUND IT !
#1227470
05/05/12 05:20 AM
05/05/12 05:20 AM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
When I put the car away last Nov. my fuel pressure was jumping all over the place . I went thru everything last week and found nothing wrong--all clean . Maybe its the gauge ? Well, I was under the car checking stuff and noticed my 5/8 aluminum fuel line had a couple visible kinks....... I got a closer look and found this --- no idea how it happened or when ! I cut the fuel line in the center of the kink....
Re: Fuel pressure problem -- FOUND IT !
[Re: 493_DART]
#1227471
05/05/12 05:23 AM
05/05/12 05:23 AM
493_DART
Worst Weather USA
Car ran great last race......the line is inside the sub frame connecter against the floor---kink was near door area ...... so.... glad i saw it !
[Re: 69CHARGERMD]
#1227473
05/05/12 09:23 AM
05/05/12 09:23 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Good find! I had a chassis dyno operator get my rubber fuel line in one of the tie down straps one time. That was confusing, car had good fuel pressure 5 minutes before I pulled it on the rollers. Of course we didn't figure this out until I had cleaned the fuel filter and looked everything else over. How he managed to grab the small segment of rubber line that you can't even see I have no idea lol.
68 Barracuda Formula S 340
[Re: tubtar]
#1227481
05/05/12 11:02 PM
05/05/12 11:02 PM
Posts: 522 Lenox Iowa
MMiller
Lenox Iowa
Did you loan your car to Bo Duke while the General was getting worked on?
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver, 90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
