Fuel pressure problem -- FOUND IT ! #1227470
05/05/12 05:20 AM
05/05/12 05:20 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
When I put the car away last Nov. my fuel pressure was jumping all over the place . I went thru everything last week and found nothing wrong--all clean . Maybe its the gauge ?
Well, I was under the car checking stuff and noticed my 5/8 aluminum fuel line had a couple visible kinks.......
I got a closer look and found this --- no idea how it happened or when !
I cut the fuel line in the center of the kink....
Re: Fuel pressure problem -- FOUND IT ! [Re: 493_DART] #1227471
05/05/12 05:23 AM
05/05/12 05:23 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Car ran great last race......the line is inside the sub frame connecter against the floor---kink was near door area ......
so....
glad i saw it !
Re: Fuel pressure problem -- FOUND IT ! [Re: 493_DART] #1227472
05/05/12 06:35 AM
05/05/12 06:35 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Good find
Re: Fuel pressure problem -- FOUND IT ! [Re: 69CHARGERMD] #1227473
05/05/12 09:23 AM
05/05/12 09:23 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Good find! I had a chassis dyno operator get my rubber fuel line in one of the tie down straps one time. That was confusing, car had good fuel pressure 5 minutes before I pulled it on the rollers. Of course we didn't figure this out until I had cleaned the fuel filter and looked everything else over. How he managed to grab the small segment of rubber line that you can't even see I have no idea lol.
68 Barracuda Formula S 340
Re: Fuel pressure problem -- FOUND IT ! [Re: 493_DART] #1227474
05/05/12 09:30 AM
05/05/12 09:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats a pretty good whack on that tube... and you
said that was INSIDE the frame connector
Re: Fuel pressure problem -- FOUND IT ! [Re: MR_P_BODY] #1227475
05/05/12 09:37 AM
05/05/12 09:37 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
The competition seems brutal these days...
Re: Fuel pressure problem -- FOUND IT ! [Re: BigBlockMopar] #1227476
05/05/12 09:53 AM
05/05/12 09:53 AM
tboomer Offline
tboomer  Offline
Good catch,Kevin! Looks like someone snuck under the car with a ball peen hammer..
Re: Fuel pressure problem -- FOUND IT ! [Re: tboomer] #1227477
05/05/12 11:03 AM
05/05/12 11:03 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Anything explode under the car recently?
Re: Fuel pressure problem -- FOUND IT ! [Re: bobby66] #1227478
05/05/12 12:57 PM
05/05/12 12:57 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
did someone put a jack under the car and it slipped??
Re: Fuel pressure problem -- FOUND IT ! [Re: dartman366] #1227479
05/05/12 07:56 PM
05/05/12 07:56 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Nope not a jack ....
Re: Fuel pressure problem -- FOUND IT ! [Re: 493_DART] #1227480
05/05/12 08:51 PM
05/05/12 08:51 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
A Jill ?
Re: Fuel pressure problem -- FOUND IT ! [Re: tubtar] #1227481
05/05/12 11:02 PM
05/05/12 11:02 PM
Lenox Iowa
MMiller Offline
MMiller  Offline
Lenox Iowa
Did you loan your car to Bo Duke while the General was getting worked on?
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver,
90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
