Does anyone make a gear lower than 3.54 for Dana 60? #1226138
05/02/12 06:57 PM
05/02/12 06:57 PM
Tennessee
Hemi ragtop Offline OP
Tennessee
From the start I built the Coronet convertable to drive. With 600+ ft.lb of torque, the 3.54 gear Dana seems to be geared too low. Even at part throttle a 1-2 gear change doesn't bring the rpms down at all. Instead, it feels like being rearended by a Grayhound bus! The 727 has a 9-1/2" 3,500 stall converter that is pretty calm at cruising speed. I think I could use an even lower gear, maybie as low as 3.0. Does anyone make a gear lower than 3.54 for the Dana 60?
Re: Does anyone make a gear lower than 3.54 for Dana 60? [Re: Hemi ragtop] #1226139
05/02/12 07:05 PM
05/02/12 07:05 PM
AndyF Offline
AndyF  Offline
I don't think so. There were a few higher gears made at one time for a certain application, but I do not think anything is currently made. Call DoctorDiff, he knows everything.
I have the same issue with my car. I have a 512 inch engine and a 5 speed Doug Nash. I need something around 3.0 rear gear. I haven't decided if I'm going to change the transmission, or swap in a 9 inch.
Re: Does anyone make a gear lower than 3.54 for Dana 60? [Re: AndyF] #1226140
05/02/12 07:30 PM
05/02/12 07:30 PM
Cement Under Ground
666 Offline
666  Offline
Cement Under Ground
There was a 321 gear for a Dana back in the 80s but this rear end gear might not adapt into a sixties dana.You would have to do some internet research.
Re: Does anyone make a gear lower than 3.54 for Dana 60? [Re: Hemi ragtop] #1226141
05/02/12 08:09 PM
05/02/12 08:09 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
In 1968 there was a 3.31 gear avalable for the Dana 60.
Nautilus Racing-
Re: Does anyone make a gear lower than 3.54 for Dana 60? [Re: Hemi ragtop] #1226142
05/02/12 08:17 PM
05/02/12 08:17 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
There was a 3.08 gear set for the 1990 D250 with a Cummins. They're pretty hard to find.
- Stu Harmon
Re: Does anyone make a gear lower than 3.54 for Dana 60? [Re: Hemi ragtop] #1226143
05/02/12 08:20 PM
05/02/12 08:20 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
I know there were a few people on here who were using Dana 70 power loks and ring & pinions in 60 housing with very little modification.. so that would open up the possiblility of a 3.07 gear. Another option that may be doable with some creativity would be a Dana 61 3.07 gear into a 60 housing. I don't have any idea what the issues would be but it might be worth looking into. Even if these gears are no longer available from Dana they should be easier to find than a Dana 60 3.30 gear.
Re: Does anyone make a gear lower than 3.54 for Dana 60? [Re: feets] #1226144
05/02/12 08:28 PM
05/02/12 08:28 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
The D350s too (w/727 auto trans). IIRC the 3.08 gearset requires its own carrier so try to get everything rather than just the ring & pinion...
Re: Does anyone make a gear lower than 3.54 for Dana 60? [Re: YYZ] #1226145
05/02/12 08:48 PM
05/02/12 08:48 PM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
1980-82 ford F250 hade 3.33
Re: Does anyone make a gear lower than 3.54 for Dana 60? [Re: bp27] #1226146
05/02/12 09:50 PM
05/02/12 09:50 PM
I think if you look on the center section you will see that it has 60-1 cast into it. Not quite the same as the standard Dana 60s I would like to find one of the Dana 60-1 out of a mid 1970 Ford 3/4 ton truck with the 360 V8 and the four speed truck trannys with the 3.30 gears in it, I would have it cut down for my Duster OP, how about using a lot taller tire on the rear to slow the cruise RPM down I did
Re: Does anyone make a gear lower than 3.54 for Dana 60? [Re: feets] #1226147
05/02/12 11:23 PM
05/02/12 11:23 PM
michigan woods
imfixinmopars426 Offline
michigan woods
careful! those are a special offset pinion case diff. huge pinion caused the offset,will not fit in a standard case. ck info on any "under 3.54" gearsets....the pinion may not fit!!! mike
Re: Does anyone make a gear lower than 3.54 for Dana 60? [Re: Cab_Burge] #1226148
05/02/12 11:26 PM
05/02/12 11:26 PM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
that photo is the 3.33 dana 60 gear I have in my 1967 b body dana 60 this photo is dana 61 3.31 ring gear
Re: Does anyone make a gear lower than 3.54 for Dana 60? [Re: Hemi ragtop] #1226149
05/03/12 12:11 AM
05/03/12 12:11 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
That is why I put a Gear Venders in my 512 powered 69 Bee. I can cruse 70 mph at 2500 rpm.
