Re: Does anyone make a gear lower than 3.54 for Dana 60?
[Re: Hemi ragtop]
#1226139
05/02/12 07:05 PM
05/02/12 07:05 PM
Posts: 31,068 Oregon
AndyF
I don't think so. There were a few higher gears made at one time for a certain application, but I do not think anything is currently made. Call DoctorDiff, he knows everything.
I have the same issue with my car. I have a 512 inch engine and a 5 speed Doug Nash. I need something around 3.0 rear gear. I haven't decided if I'm going to change the transmission, or swap in a 9 inch.
[Re: Hemi ragtop]
#1226141
05/02/12 08:09 PM
05/02/12 08:09 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
In 1968 there was a 3.31 gear avalable for the Dana 60.
[Re: Hemi ragtop]
#1226142
05/02/12 08:17 PM
05/02/12 08:17 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
There was a 3.08 gear set for the 1990 D250 with a Cummins. They're pretty hard to find.
[Re: feets]
#1226144
05/02/12 08:28 PM
05/02/12 08:28 PM
Posts: 7,327 Toronto (YYZ) Ontario
YYZ
The D350s too (w/727 auto trans). IIRC the 3.08 gearset requires its own carrier so try to get everything rather than just the ring & pinion...
[Re: feets]
#1226147
05/02/12 11:23 PM
05/02/12 11:23 PM
Posts: 4,041 michigan woods
imfixinmopars426
michigan woods
careful! those are a special offset pinion case diff. huge pinion caused the offset,will not fit in a standard case. ck info on any "under 3.54" gearsets....the pinion may not fit!!! mike
