checkered racing back half kits ?????? #1225568
05/01/12 07:08 PM
05/01/12 07:08 PM
nc
E
earthmover Offline OP
E
nc
http://stores.checkeredracing.com/catalog/4Link4L.jpg
anybody ever use 1 of this kits??? good bad?????price looks pretty good..what do you guys think or what would you change in the kit?????
Re: checkered racing back half kits ?????? [Re: earthmover] #1225569
05/01/12 08:51 PM
05/01/12 08:51 PM
dan1320 Offline
dan1320  Offline
I bought one and installed it but the car isn't finished so I don't have any laps on the car. I can tell you it measured out fine and installed cleanly if that helps you at all.
Dan
Re: checkered racing back half kits ?????? [Re: dan1320] #1225570
05/01/12 10:12 PM
05/01/12 10:12 PM
Guitar Jones Offline
I bought the 4 link backhalf from them that's in the Scamp. No problems but I did get CM rod ends. There are things about it I'd like different like some flats on the bars but over all for the price it was a good deal.
Re: checkered racing back half kits ?????? [Re: Guitar Jones] #1225571
05/01/12 10:16 PM
05/01/12 10:16 PM
nc
E
E
nc
i was looking at your build pics from abodies the other day..
Re: checkered racing back half kits ?????? [Re: Guitar Jones] #1225572
05/02/12 12:23 AM
05/02/12 12:23 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
[ There are things about it I'd like different like some flats on the bars but over all for the price it was a good deal.
I have done this before. Get 4 nuts that are just a little larger than the 4 link tubes. Bore the centers out on a lathe or just drill them out big enough to slide over your tubes and have them tigged on the bars where it is easy to reach while making adjustments. Make sure to clean all the zinc/cadium plating off of the nuts before welding. Beep
Re: checkered racing back half kits ?????? [Re: Bigbeep] #1225573
05/02/12 12:39 AM
05/02/12 12:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
For a few bucks more you can buy the tube inserts
with the hex on them(all the inserts I use the LH
insert has the hex and looks nicer)... also that
kit shown doesnt have a back brace on the rear end
(thats a MUST in my opinion) so it MIGHT require a
longer set of shock mounts to clear the back brace
which is no big deal but keep it in mind... other
than that it looks like ALL the rest of that style
back halfs... unless you go with a wish bone locator
Re: checkered racing back half kits ?????? [Re: Bigbeep] #1225574
05/02/12 06:49 AM
05/02/12 06:49 AM
Good idea. Thanks.
Re: checkered racing back half kits ?????? [Re: earthmover] #1225575
05/02/12 08:40 AM
05/02/12 08:40 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
I'm quite sure thats a good kit but, depending on how much power now or in the future you will be putting back there, you may want to go with larger bars...anyways, they will need some sort of HEX or nut for adjustments...
