What do your 68-69 barracudas weigh? #1225556
05/01/12 06:59 PM
05/01/12 06:59 PM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
Im gonna build a 68 barracuda fastback and Im probably gonna build the motor first so I wanna know how much the cars normally weigh at race weight. Im shooting for 6.40 or 6.50 in the 1/8. So if you could let me know how much yours weighs and what you did to get it there. Im planning on back halfing and using ladder bars or 4 link with a dana. The front will be fiberglass for the most part. The motor will likely be a 400.
Thanks guys
Re: What do your 68-69 barracudas weigh? [Re: Jonnyj00] #1225557
05/01/12 10:36 PM
05/01/12 10:36 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Our old 69 notchback with a 440 weighed 3050.
Re: What do your 68-69 barracudas weigh? [Re: MIKES_DUSTER] #1225558
05/01/12 11:01 PM
05/01/12 11:01 PM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
back halfed?
Re: What do your 68-69 barracudas weigh? [Re: Jonnyj00] #1225559
05/02/12 12:36 AM
05/02/12 12:36 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Mine is a pig! Stock floor with mini tubs, glass fenders, hood, bumpers, original tinted windows, still has dash , carpet, door panels, 12 point cage, filled RB with indy heads, wilwoods all around. Should be around 3125 now without me in it. Just lost a couple pounds up front this winter. Beep
Re: What do your 68-69 barracudas weigh? [Re: Bigbeep] #1225560
05/02/12 12:54 AM
05/02/12 12:54 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Without my 100 lbs ballast and me it weighs right at 2500. Future plans call for a new front clip to get rid of the stock suspension and install Lamb struts and R&P. At least another 100+ will come off.
Re: What do your 68-69 barracudas weigh? [Re: Blucuda413] #1225561
05/02/12 02:55 AM
05/02/12 02:55 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Both of mine weigh entirely to much
Re: What do your 68-69 barracudas weigh? [Re: Al_Alguire] #1225562
05/02/12 09:56 AM
05/02/12 09:56 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
3250#'s as seen in my sig (with 170# driver). 6 pt bar, no fiberlgass, small block.
In the past few years I have switched to a fiberglass hood, added CalTrac mono's, light weight starter, and a few other things to loose weight, but I have not re-weighed the car...I'm guessing I'm probably about 3200#'s now (with driver).
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: What do your 68-69 barracudas weigh? [Re: FlyFish] #1225563
05/03/12 09:56 PM
05/03/12 09:56 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Tube chassis, fiberglass hood = 3,100 lbs with driver.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: What do your 68-69 barracudas weigh? [Re: Jonnyj00] #1225564
05/03/12 09:58 PM
05/03/12 09:58 PM
back halfed?
No...Dana,Ladder Bars with Floaters.
Re: What do your 68-69 barracudas weigh? [Re: MIKES_DUSTER] #1225565
05/03/12 10:05 PM
05/03/12 10:05 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
2,650#'s with 12 point cage, w/o driver. Gutted, with glass front end , rear deck lid, and rear bumper.
Good luck,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: What do your 68-69 barracudas weigh? [Re: cudabin] #1225566
05/04/12 12:20 AM
05/04/12 12:20 AM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
3,050lbs small block, edelbrock heads, 727, full 3" exhaust, stock front seat, bottom of the back seat, consol and stock shifter, stock dash, frame connectors, 8 3/4, cal-tracks, mono leafs, strange front brakes, 6 point mild steel roll cage, no fiberglass, steel bumpers, not mini-tubed, inner fender wells still in, stock floor boards, 5 gal alumin fuel cell in trunk and so is the battery and fuel pump. Heat/air unit removed.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
68 Fastback [Re: WadeMetzinger] #1225567
05/04/12 01:01 AM
05/04/12 01:01 AM
DC, MD Suburbs
440PURSUIT Offline
440PURSUIT  Offline
DC, MD Suburbs
Mine (Fastback) was 3205lb wo driver. Aluminum headed, Iron block Hemi, Ford 9", Ladder Bar /Leaf.
1969 Hemi Charger R/T,
1970 Charger 472 Hemi 6 Sp
1969 Charger Pro Tour Project
1971 Barracuda Convert
1970 440 6pack Superbird,
1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue)
1967 Barracuda Convert
1968 Barracuda Coupe
1972 Charger Rallye wanna be RT
1972 Sebring Plus 440-6 Clone
1969 Coronet Pro Street
2009 Challengeer SRT8 stick
1992-1986 Body 2500 4x4 440 stick
1982 Ramcharger 318 Sniper- getting enhanced.
1991.5 W250 Cummins- Big Chief
