Re: What do your 68-69 barracudas weigh?
[Re: Jonnyj00]
#1225559
05/02/12 12:36 AM
05/02/12 12:36 AM
Posts: 1,165 Central Ohio, USA
Bigbeep
Central Ohio, USA
Mine is a pig! Stock floor with mini tubs, glass fenders, hood, bumpers, original tinted windows, still has dash , carpet, door panels, 12 point cage, filled RB with indy heads, wilwoods all around. Should be around 3125 now without me in it. Just lost a couple pounds up front this winter. Beep
[Re: Al_Alguire]
#1225562
05/02/12 09:56 AM
05/02/12 09:56 AM
Posts: 1,178 Indy
FlyFish
Indy
3250#'s as seen in my sig (with 170# driver). 6 pt bar, no fiberlgass, small block.
In the past few years I have switched to a fiberglass hood, added CalTrac mono's, light weight starter, and a few other things to loose weight, but I have not re-weighed the car...I'm guessing I'm probably about 3200#'s now (with driver).
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: FlyFish]
#1225563
05/03/12 09:56 PM
05/03/12 09:56 PM
Posts: 16,483 On the run…
BloFish
On the run…
Tube chassis, fiberglass hood = 3,100 lbs with driver.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: MIKES_DUSTER]
#1225565
05/03/12 10:05 PM
05/03/12 10:05 PM
Posts: 903 Saskatchewan, Canada
cudabin
2,650#'s with 12 point cage, w/o driver. Gutted, with glass front end , rear deck lid, and rear bumper.
Good luck,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: cudabin]
#1225566
05/04/12 12:20 AM
05/04/12 12:20 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
3,050lbs small block, edelbrock heads, 727, full 3" exhaust, stock front seat, bottom of the back seat, consol and stock shifter, stock dash, frame connectors, 8 3/4, cal-tracks, mono leafs, strange front brakes, 6 point mild steel roll cage, no fiberglass, steel bumpers, not mini-tubed, inner fender wells still in, stock floor boards, 5 gal alumin fuel cell in trunk and so is the battery and fuel pump. Heat/air unit removed.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
68 Fastback
[Re: WadeMetzinger]
#1225567
05/04/12 01:01 AM
05/04/12 01:01 AM
Posts: 1,548 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
Mine (Fastback) was 3205lb wo driver. Aluminum headed, Iron block Hemi, Ford 9", Ladder Bar /Leaf.
1969 Hemi Charger R/T, 1970 Charger 472 Hemi 6 Sp 1969 Charger Pro Tour Project 1971 Barracuda Convert 1970 440 6pack Superbird, 1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue) 1967 Barracuda Convert 1968 Barracuda Coupe 1972 Charger w 383 1972 Sebring Plus 440-6 Clone 1969 Coronet Pro Street 2009 Challengeer SRT8 stick 1992-1986 Body 2500 4x4 440 stick 1982 Ramcharger 318 Sniper- getting enhanced. 1997 Ram B3500 Van 5.9 1991.5 W250 Cummins- Big Chief
