cryogenics ? #1223017
04/27/12 10:46 AM
04/27/12 10:46 AM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Just wondering if anyone is using this process other than rocker arms? Cranks or blocks?
Re: cryogenics ? [Re: mac56] #1223018
04/27/12 11:59 AM
04/27/12 11:59 AM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
In addition, we have used cryo on roller lifters, heads, valve springs, valves, and keepers, lots of items benefit from cryo.
Be a Rebel- Break the Laws of Physics!
Re: cryogenics ? [Re: mbogina] #1223019
04/27/12 12:24 PM
04/27/12 12:24 PM
Sullivan, Ohio
Max Wedge Savoy Offline
Sullivan, Ohio
My cast Stock Eliminator crank was cryo'd. Never had an issue with it after.
Re: cryogenics ? [Re: mbogina] #1223020
04/27/12 12:33 PM
04/27/12 12:33 PM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
along with those, I have also done the ring and pinion.
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: cryogenics ? [Re: mac56] #1223021
04/27/12 12:35 PM
04/27/12 12:35 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Is there any quantifiable data for the benefits from using cryo-treated iron, steel and aluminum parts? Everything I've found during research I did a few years ago always seemed to rely on theoretical improvements, rather than actual test results.
Re: cryogenics ? [Re: BradH] #1223022
04/27/12 01:34 PM
04/27/12 01:34 PM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
We had lots of problems with the Comp Cams 829 Roller Lifters when used w big spring pressures, we basically crushed the rollers and turned them to dust. The cryo lifters appear to last about 3 times as long as the non-cryo in this application.
I don't have measurable results on any other items. I had worked a deal to dyno a Super Stock Hemi motor, have everything cryo treated and re-dyno, but we never went through with it.
Re: cryogenics ? [Re: mbogina] #1223023
04/27/12 01:41 PM
04/27/12 01:41 PM
wine country
8
8urvette Online content
8urvette  Online Content
wine country
my cousin runs a 11 sec srt4- full interior just built motor on slicks. blew apart a few input shafts. paid to get one cryo treated and has been running it for 2-3 years now problem free. mind u he had exploded the "new" input shaft at the first event it went to. the original had help up till the low 11's, then let go, the replacement died the first weekend and the cryo has held up for years, exact same car, same setup, set et's and same weight. sounds like some proof to me-
o yea, and its a daily driver too!
Re: cryogenics ? [Re: mbogina] #1223024
04/27/12 04:02 PM
04/27/12 04:02 PM
BradH Offline
BradH  Offline
... The cryo lifters appear to last about 3 times as long as the non-cryo in this application.
That's definitely of interest to me...
Re: cryogenics ? [Re: mac56] #1223025
04/27/12 04:32 PM
04/27/12 04:32 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
I had an assortment of parts including crank and block done about 8 years ago. A friend of mine offers this service and did my parts at the time to fill in and make a full batch.
I don't have anything to compare to so I don't know whether or not the cryo treatment works or did not on my application.
What my buddy did indicated when I was discussing this was the feedback he recieved from a company whom he did their brake rotors for. Apparently, the treated rotors would hold up much better than the untreated ones.
Re: cryogenics ? [Re: cruzin] #1223026
04/27/12 05:14 PM
04/27/12 05:14 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
A member had his whole motor cryo'ed. Apparently it is not a good idea to cryo compressed valve springs. His valve springs lost pressure after a dozen or so passes, and some street miles.
He talked with somebody (dont know who) and they said that due to being compressed when cryo'd it messed with the metallurgy...somehow.
Take it FWIW....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: cryogenics ? [Re: Von] #1223027
04/27/12 06:21 PM
04/27/12 06:21 PM
Sullivan, Ohio
Sullivan, Ohio
Take it FWIW....
When a part is chilled to those temps there is a change to the grain structure. I would further explain it but I'm afraid I would bore everyone.
Re: cryogenics ? [Re: Max Wedge Savoy] #1223028
04/27/12 08:09 PM
04/27/12 08:09 PM
dogdays Offline
dogdays  Offline
Not me, but in college I was the only one who voted for Advanced Metallurgy as an elective!
Thomas Schoonover, R.I.P.
R.
Re: cryogenics ? [Re: dogdays] #1223029
04/27/12 09:03 PM
04/27/12 09:03 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I had the gears in my Richmond street trans cryo treated and I beat the crap out of that tranny with an "old-school" Hays Pro-Stock clutch and bronze disc and it held up just fine
Gus
64 Plymouth Savoy
Dana 60
Re: cryogenics ? [Re: dogdays] #1223030
04/27/12 09:08 PM
04/27/12 09:08 PM
MN
hemidup Offline
hemidup  Offline
MN
I cyro'd every internal part in my engine, valves, springs, rod's, piston's, rings, bearings, crank, ARP main and head stud's etc plus the block. Cheap insurance.
Jerry Williams.
Re: cryogenics ? [Re: hemidup] #1223031
04/27/12 11:22 PM
04/27/12 11:22 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
a friend is a machinest at tyco and their tooling lasts longer when cryoed. i asked if it is snake oil and he said it makes things last longer.
Re: cryogenics ? [Re: dmking] #1223032
04/27/12 11:48 PM
04/27/12 11:48 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
dang I never knew. could easy take my stuff to work and chryo them... dont know how long or how slow to bring the temp down etc.. I work in a ASU plant (air separation unit) we make Lox (liquid o2) LIN (liquid N2) and Lar (liquid Argon) by the tons...
hmm...
Re: cryogenics ? [Re: Bob_Coomer] #1223033
04/28/12 02:24 AM
04/28/12 02:24 AM
west coast
P
produster Offline
produster  Offline
P
west coast
Liberty Gears, Liberty transmissions, cryos everything. I have not seen a failure in the trans that was caused by broken internals.
Re: cryogenics ? [Re: produster] #1223034
04/28/12 10:16 AM
04/28/12 10:16 AM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
I believe Bryant cryo's all their cranks.
Re: cryogenics ? [Re: dmking] #1223035
04/28/12 11:58 AM
04/28/12 11:58 AM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
I also have a freind that owns a machine shop that produces aircraft parts (extremely tight tolerances) and he's claimed that cryo treated tooling lasts as much as 5 times longer. Sort of makes me want to try it..
Re: cryogenics ? [Re: Bob_Coomer] #1223036
04/28/12 01:07 PM
04/28/12 01:07 PM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
hmm...
The process consists of slowly lowering the temperature to -320 over a period of hours, holding it at that temp for another time period, and then slowly raising it back to ambient. One of my friends here in Tucson had a cryo treatment business, but subsequently sold it. As I recall, it took over 24 hours to complete the process.
