Indy heads and gasket issues #1222818
04/26/12 10:25 PM
04/26/12 10:25 PM
jacksonville,FLORIDA
slammedR/T Offline OP
I have a set of Indy 360-1 245cnc heads that I thought was ready to bolt on when I ran into a problem. The intakes gaskets aren't tall enough and cover the roof of the intake runner. I ordered the 360-G1-276 which on Indy's website is supposed to be the right gasket, anyone run into this and got another part number?
DEPUTY
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Indy heads and gasket issues [Re: slammedR/T] #1222819
04/27/12 01:14 AM
04/27/12 01:14 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Are these new heads? If so have you checked your intake to see how it lines up?
I know on a buddys set-up with 360-1 245 the ports are raised (I don't think all 245's are the same). I know on his the intake manifold had to be spaced up and port matched. His ports are higher than my older 360-1 heads.
"Just a Bracket car dressed up like a streetcar"
Re: Indy heads and gasket issues [Re: Just-a-dart] #1222820
04/27/12 01:20 AM
04/27/12 01:20 AM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
You're going to Have to custom make them yorself, your heads are only cnc at this point? Or did you port them from there?
Re: Indy heads and gasket issues [Re: SB449VALIANT] #1222821
04/27/12 12:14 PM
04/27/12 12:14 PM
They are as cnc'd from Indy as far as i know, i bought them from a guy on racingjunk. He had them converted to T&D rockers, valve job and comp elite polished springs from SSDS oh and race valve job from ryan also. I guess I need to call him and see what gaskets he used, gonna call Indy also.
DEPUTY
racemagnum
Re: Indy heads and gasket issues [Re: slammedR/T] #1222822
04/27/12 02:56 PM
04/27/12 02:56 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
DEPUTY
Skip calling Indy, and just call Ryan. You will thank me later.
Re: Indy heads and gasket issues [Re: Dragula] #1222823
04/27/12 03:39 PM
04/27/12 03:39 PM
Mcallen, TX
Mcallen, TX
DEPUTY
