Indy heads and gasket issues
#1222818
04/26/12 10:25 PM
04/26/12 10:25 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
I have a set of Indy 360-1 245cnc heads that I thought was ready to bolt on when I ran into a problem. The intakes gaskets aren't tall enough and cover the roof of the intake runner. I ordered the 360-G1-276 which on Indy's website is supposed to be the right gasket, anyone run into this and got another part number?
DEPUTY
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
Re: Indy heads and gasket issues
[Re: slammedR/T]
#1222819
04/27/12 01:14 AM
04/27/12 01:14 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Are these new heads? If so have you checked your intake to see how it lines up?
I know on a buddys set-up with 360-1 245 the ports are raised (I don't think all 245's are the same). I know on his the intake manifold had to be spaced up and port matched. His ports are higher than my older 360-1 heads.
"Just a Bracket car dressed up like a streetcar"
[Re: SB449VALIANT]
#1222821
04/27/12 12:14 PM
04/27/12 12:14 PM
slammedR/T
They are as cnc'd from Indy as far as i know, i bought them from a guy on racingjunk. He had them converted to T&D rockers, valve job and comp elite polished springs from SSDS oh and race valve job from ryan also. I guess I need to call him and see what gaskets he used, gonna call Indy also.
DEPUTY
[Re: slammedR/T]
#1222822
04/27/12 02:56 PM
04/27/12 02:56 PM
Posts: 12,391 Taxes & Virus's R-US, NY
Dragula
DEPUTY
Skip calling Indy, and just call Ryan. You will thank me later.
[Re: Dragula]
#1222823
04/27/12 03:39 PM
04/27/12 03:39 PM
Posts: 1,418 Mcallen, TX
SB449VALIANT
Mcallen, TX
DEPUTY
