Re: ShoGun water pump system users? [Re: 52savoy] #1222526
04/28/12 03:06 PM
04/28/12 03:06 PM
Rock Springs
Bob_Coomer Offline OP
Rock Springs
how hard would it be to set this ShoGun system up for reverse cooling? I mean is it as simple as switching the lines to run water through the heads first?
Re: ShoGun water pump system users? [Re: Bob_Coomer] #1222527
04/28/12 03:09 PM
04/28/12 03:09 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I wondered the same thing. I have 3 different styles of pumps but no SHOGAN.. I was going to mock up some water lines and test flow where the water exits. What do you think?
oh.. I forgot. I also have blocks very similar to Andy's I thought about trying out.
Re: ShoGun water pump system users? [Re: 52savoy] #1222528
04/28/12 03:19 PM
04/28/12 03:19 PM
Rock Springs
Rock Springs
I picked this system up used and got around to checking it out yesterday... Hooked the motor up and it sounded funny...
Pulled the small pump cover off and the impeller is toast... It was actually like chewed bubble gum, Found a repair kit on line for fairly cheap. Like $20 for two impellers. Not sure if the cheap aftermarket replacement impellers can hold up to the much hotter temps of a race car however. These pumps are pretty much cheap garden or bilge pumps.
Re: ShoGun water pump system users? [Re: Bob_Coomer] #1222529
04/28/12 03:35 PM
04/28/12 03:35 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
i use a demco bilge pump and a WP136 mezier pump in my intercooler system but not on the engine yet but have the radiator with an fitting allready.
Re: ShoGun water pump system users? [Re: 52savoy] #1222530
05/09/12 11:29 PM
05/09/12 11:29 PM
Rock Springs
Rock Springs
I been looking and looking for a water pump that is suitable for a race car.. Lots of small remote style pumps on ebay... None are made for the higher water temps that our coolant system makes..
Finally think I found one.. and its sure is small too..
Plan to buy one and I will let you guys know how it works out...
look
http://www.sun-pump.com/pumps.htm
Re: ShoGun water pump system users? [Re: Bob_Coomer] #1222531
05/10/12 02:59 PM
05/10/12 02:59 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
3 gallons per minute ain't going to cut it I wouldn't think. Most electric warter pumps are at least 28-30 gpm. I would just go ahead and get something like a mezeire remote pump.
One day I will have something cool here.
Re: ShoGun water pump system users? [Re: sdaurity] #1222532
05/10/12 08:50 PM
05/10/12 08:50 PM
Rock Springs
Rock Springs
You might be right, but the pumps they use to sell didnt flow much either. They make some interesting points about a cooling system requirements.
read..
Re: ShoGun water pump system users? [Re: Bob_Coomer] #1222533
05/10/12 08:50 PM
05/10/12 08:50 PM
Rock Springs
Rock Springs
Re: ShoGun water pump system users? [Re: Bob_Coomer] #1222534
05/14/12 10:23 AM
05/14/12 10:23 AM
Kentucky
sc301v Offline
sc301v  Offline
Kentucky
http://www.grainger.com/Grainger/wwg/sea...&sst=subset
Been using this pump forever...And also if you have a shogun pump assembly the top will bolt directly to the grainger motor and also the mounting bracket will come off so you can use the shogun mount also.
Re: ShoGun water pump system users? [Re: Bob_Coomer] #2364557
09/03/17 01:40 PM
09/03/17 01:40 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
Anyone have a Shogun manifold that they want to sell?? Mine has sprung a small leak. Going to get it welded up. But I would like a spare!!
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: ShoGun water pump system users? [Re: Bob_Coomer] #2364559
09/03/17 01:44 PM
09/03/17 01:44 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I have 1,never used
Re: ShoGun water pump system users? [Re: Bob_Coomer] #2364684
09/03/17 04:26 PM
09/03/17 04:26 PM
Ringtown, Pa.
Ringtown, Pa.
PM sent.
Re: ShoGun water pump system users? [Re: Dartsport540] #2969475
10/01/21 11:17 PM
10/01/21 11:17 PM
MO.
CROWBAR Offline
CROWBAR  Offline
MO.
Any one have a ShoGun water pump system for sale? Looking for the expansion tank and manifold
