Re: ShoGun water pump system users?
[Re: 52savoy]
#1222526
04/28/12 03:06 PM
04/28/12 03:06 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
how hard would it be to set this ShoGun system up for reverse cooling? I mean is it as simple as switching the lines to run water through the heads first?
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#1222527
04/28/12 03:09 PM
04/28/12 03:09 PM
Posts: 4,251 State of retirement
52savoy
State of retirement
I wondered the same thing. I have 3 different styles of pumps but no SHOGAN.. I was going to mock up some water lines and test flow where the water exits. What do you think?
oh.. I forgot. I also have blocks very similar to Andy's I thought about trying out.
[Re: 52savoy]
#1222528
04/28/12 03:19 PM
04/28/12 03:19 PM
Bob_Coomer
Rock Springs
I picked this system up used and got around to checking it out yesterday... Hooked the motor up and it sounded funny... Pulled the small pump cover off and the impeller is toast... It was actually like chewed bubble gum, Found a repair kit on line for fairly cheap. Like $20 for two impellers. Not sure if the cheap aftermarket replacement impellers can hold up to the much hotter temps of a race car however. These pumps are pretty much cheap garden or bilge pumps.
[Re: 52savoy]
#1222530
05/09/12 11:29 PM
05/09/12 11:29 PM
Bob_Coomer
Rock Springs
I been looking and looking for a water pump that is suitable for a race car.. Lots of small remote style pumps on ebay... None are made for the higher water temps that our coolant system makes.. Finally think I found one.. and its sure is small too.. Plan to buy one and I will let you guys know how it works out... look http://www.sun-pump.com/pumps.htm
[Re: Bob_Coomer]
#2364557
09/03/17 01:40 PM
09/03/17 01:40 PM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
Anyone have a Shogun manifold that they want to sell?? Mine has sprung a small leak. Going to get it welded up. But I would like a spare!!
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: Dartsport540]
#2969475
10/01/21 11:17 PM
10/01/21 11:17 PM
Posts: 81 MO.
CROWBAR
MO.
Any one have a ShoGun water pump system for sale? Looking for the expansion tank and manifold
