fuel pressure regulator mounting #1220448
04/22/12 01:13 PM
04/22/12 01:13 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Hey guys,
Trying to get an idea of where and how to mount a single holley 803 non return style regulator. If anyone has any pics of this it would be greatly appreciated. I know a lot of guys mount them on the fenders, but was thinking of mounting it somewhere off the engine possibly? Not sure what is allowed though in the NHRA rules.
Any pics or insight would be great!
Thanks!
Matthew
Re: fuel pressure regulator mounting [Re: mshred] #1220449
04/22/12 01:19 PM
04/22/12 01:19 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
1.39 9.85 - 137 mph
Re: fuel pressure regulator mounting [Re: mshred] #1220450
04/22/12 01:59 PM
04/22/12 01:59 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
here's mine
Re: fuel pressure regulator mounting [Re: rickraw] #1220451
04/22/12 02:02 PM
04/22/12 02:02 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
here's mine
thats a cool little bracket...did you make it, or can you buy that from a manufacturer?
Re: fuel pressure regulator mounting [Re: mshred] #1220452
04/22/12 02:08 PM
04/22/12 02:08 PM
Ambridge, Pa.
Ambridge, Pa.
it was on there when i got the car. i beleive it's from magna flow
Re: fuel pressure regulator mounting [Re: rickraw] #1220453
04/22/12 02:45 PM
04/22/12 02:45 PM
sweden
sshemi Offline
sshemi  Offline
sweden
I bought one of those from jegs complete with fittings and tubing.
Not the best quality and fit, but ti works and looks good.
Re: fuel pressure regulator mounting [Re: rickraw] #1220454
04/22/12 02:46 PM
04/22/12 02:46 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
On single carb set ups we always "hang" them by the carb from the lines. No reason to mount one anywhere else really, plus it get the reg as close as possible to the carb.
Re: fuel pressure regulator mounting [Re: Al_Alguire] #1220455
04/22/12 03:33 PM
04/22/12 03:33 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
I was never sure if hanging them without mounting them solid to something was acceptable. But if hanging them is okay, then that might be the best option it seems. Only thing is im using push lok, not stainless braided hose....should work similar though I would think and be able to support it
Re: fuel pressure regulator mounting [Re: Al_Alguire] #1220456
04/22/12 06:25 PM
04/22/12 06:25 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
ideally you want to mount the regulator ahead (front) of the carb or carbs. with the reduced psi you don't want the g-forces keeping the fuel from the carb.
Re: fuel pressure regulator mounting [Re: mshred] #1220457
04/22/12 06:50 PM
04/22/12 06:50 PM
Az
Crizila Offline
Crizila  Offline
Az
I think the only stipulation was a minimum of 6" in front of the firewall. I'm not a big fan of mounting the fuel press. reg solid to the engine in any way - but lots do it without a problem.
Fastest 300
Re: fuel pressure regulator mounting [Re: nss guy] #1220458
04/22/12 07:18 PM
04/22/12 07:18 PM
Mount it on the elephant ears below the alternator or on the radiator support, on anything anywhere in front of the carb.
Re: fuel pressure regulator mounting [Re: Cab_Burge] #1220459
04/22/12 11:43 PM
04/22/12 11:43 PM
Az
Crizila Offline
Crizila  Offline
Az
Supply and demand folks. If you have enough pressure an volume to the reg, it aint gonna make no difference which way that -6 or -8 line is pointing. Liquid doesn't compress. The pump might have to work a little bit harder, but if you have enough pump, it's gonna stay @ 7 psi. - or where ever you set it.
Fastest 300
Re: fuel pressure regulator mounting [Re: Cab_Burge] #1220460
04/23/12 02:02 AM
04/23/12 02:02 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I dont think ANYONE here is making enough steam to worry about the regulator being affected by Gforce..Just saying lets not over think this.
Re: fuel pressure regulator mounting [Re: Al_Alguire] #1220461
04/23/12 02:13 AM
04/23/12 02:13 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
A-Men!
Re: fuel pressure regulator mounting [Re: Biginchmopar] #1220462
04/23/12 10:33 AM
04/23/12 10:33 AM
Az
Crizila Offline
Crizila  Offline
Az
A-Men!
FoSho!
Fastest 300
Re: fuel pressure regulator mounting [Re: mshred] #1220463
04/23/12 11:43 AM
04/23/12 11:43 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
shameless plug here...these work and look great..and yes I sell them.
RIP Monte Smith
Re: fuel pressure regulator mounting [Re: CompWedgeEngines] #1220464
04/23/12 07:50 PM
04/23/12 07:50 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Thanks for the pics guys! just trying to get some ideas if I end up running motor only and using only one reg. Todd, I will hit you up for that bracket if I do Still haven't decided if im going to strap on the cheater kit that I already have- I have the two regs and a magnafuel dual port log, just need to make up my mind
Re: fuel pressure regulator mounting [Re: mshred] #1220465
04/28/12 05:43 PM
04/28/12 05:43 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
I built a plate that came off the intake and has the reg mounted to it. Works for me.
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: fuel pressure regulator mounting [Re: chryco] #1220466
04/28/12 06:11 PM
04/28/12 06:11 PM
Port Mcneill,B.C.Canada
I
Islandcuda Offline
Islandcuda  Offline
I
I have my main line coming around the motor side of my distributor and have the regulator just floating on the 2 lines from the carb. No mounting no nothing, it just hangs there in mid air and hasn,t given me any problems in 7 or 8 years.
67 cuda new best 1.395 60 10.240 at 128.58mph
Re: fuel pressure regulator mounting [Re: chryco] #1220467
04/28/12 06:23 PM
04/28/12 06:23 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
believe me when i tell you that "problem" borders on urban legend along with the totally incorrect notion that the larger the diameter of the front to rear line makes this "problem" worse. the diameter has no effect with regards to any g-force impact it's the linear length that does.
water exerts roughly .433 psi per foot and the specific gravity of race fuels runs around .725-.750 so fuels exert about .320 psi per foot. this would mean if you have 10 linear feet of line parallel with the forward motion of the car and the car is accelerating at 1G there would be 3.2 PSI of back pressure. iirc a pro stock car averages about 1.5 g during the run which of course is higher at the hit and softer at the big end.
does it have an impact, yes, is it a problem for the vast majority of racers, no
