Re: fuel pressure regulator mounting
[Re: rickraw]
#1220451
04/22/12 02:02 PM
04/22/12 02:02 PM
Posts: 3,421 Toronto
mshred
Toronto
here's mine
thats a cool little bracket...did you make it, or can you buy that from a manufacturer?
[Re: Al_Alguire]
#1220455
04/22/12 03:33 PM
04/22/12 03:33 PM
mshred
Toronto
On single carb set ups we always "hang" them by the carb from the lines. No reason to mount one anywhere else really, plus it get the reg as close as possible to the carb.
I was never sure if hanging them without mounting them solid to something was acceptable. But if hanging them is okay, then that might be the best option it seems. Only thing is im using push lok, not stainless braided hose....should work similar though I would think and be able to support it
[Re: mshred]
#1220457
04/22/12 06:50 PM
04/22/12 06:50 PM
Posts: 7,506 Az
Crizila
Az
I think the only stipulation was a minimum of 6" in front of the firewall. I'm not a big fan of mounting the fuel press. reg solid to the engine in any way - but lots do it without a problem.
Fastest 300
[Re: Cab_Burge]
#1220459
04/22/12 11:43 PM
04/22/12 11:43 PM
Posts: 7,506 Az
Crizila
Az
Supply and demand folks. If you have enough pressure an volume to the reg, it aint gonna make no difference which way that -6 or -8 line is pointing. Liquid doesn't compress. The pump might have to work a little bit harder, but if you have enough pump, it's gonna stay @ 7 psi. - or where ever you set it.
Fastest 300
[Re: Cab_Burge]
#1220460
04/23/12 02:02 AM
04/23/12 02:02 AM
Posts: 19,378 Las Vegas
Al_Alguire
Las Vegas
I dont think ANYONE here is making enough steam to worry about the regulator being affected by Gforce..Just saying lets not over think this.
[Re: mshred]
#1220463
04/23/12 11:43 AM
04/23/12 11:43 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
shameless plug here...these work and look great..and yes I sell them.
RIP Monte Smith
[Re: chryco]
#1220466
04/28/12 06:11 PM
04/28/12 06:11 PM
Posts: 501 Port Mcneill,B.C.Canada
Islandcuda
I have my main line coming around the motor side of my distributor and have the regulator just floating on the 2 lines from the carb. No mounting no nothing, it just hangs there in mid air and hasn,t given me any problems in 7 or 8 years.
67 cuda new best 1.395 60 10.240 at 128.58mph
[Re: chryco]
#1220467
04/28/12 06:23 PM
04/28/12 06:23 PM
Posts: 5,875 communist bloc of new jersey
jamesc
ideally you want to mount the regulator ahead (front) of the carb or carbs. with the reduced psi you don't want the g-forces keeping the fuel from the carb.
believe me when i tell you that "problem" borders on urban legend along with the totally incorrect notion that the larger the diameter of the front to rear line makes this "problem" worse. the diameter has no effect with regards to any g-force impact it's the linear length that does.
water exerts roughly .433 psi per foot and the specific gravity of race fuels runs around .725-.750 so fuels exert about .320 psi per foot. this would mean if you have 10 linear feet of line parallel with the forward motion of the car and the car is accelerating at 1G there would be 3.2 PSI of back pressure. iirc a pro stock car averages about 1.5 g during the run which of course is higher at the hit and softer at the big end.
does it have an impact, yes, is it a problem for the vast majority of racers, no
