Page 1 of 3 1 2 3
Holy Crap! Check this out! #1219651
04/21/12 11:52 AM
04/21/12 11:52 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
http://www.streetlegaltv.com/news/new-pr...red-by-borgeson
It was great until I saw the price...Tim
Re: Holy Crap! Check this out! [Re: astjp2] #1219652
04/21/12 11:57 AM
04/21/12 11:57 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You do realize that there is NOTHING quick about that ratio? It's stock for all power steering units.
Don't be the exception.
Re: Holy Crap! Check this out! [Re: astjp2] #1219653
04/21/12 12:01 PM
04/21/12 12:01 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
With real quick ratio boxes you have to be very carefull when driving on the street and have an emergency manuvour. I have a 12 to one box and had a fool half way across the center line on a blind curve in the hills. If I hadn't been used to the box then I would have been into the bank nose first. It's great for the autocross, but probably way too quick for a real road course.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Holy Crap! Check this out! [Re: amxautox] #1219654
04/21/12 12:27 PM
04/21/12 12:27 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
i wonder if they lightened up the box at all at that price...
Re: Holy Crap! Check this out! [Re: Supercuda] #1219655
04/21/12 12:56 PM
04/21/12 12:56 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Mopar power units were 15.7:1 Often stated as 16:1 So yes 14:1 is quick. With a long pitman it would be really quick
Re: Holy Crap! Check this out! [Re: amxautox] #1219656
04/21/12 01:16 PM
04/21/12 01:16 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
I nice development indeed!
amxautox has a good point. You would not want it to be too quick of a ratio.
These folks are offering a new Delphi box with a 14:1 ratio, which appears to be the same ratio as the WS6 TransAm box, from what I read.
WS6
What scares me more is the $750 pricetag!
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Holy Crap! Check this out! [Re: DynoDave] #1219657
04/21/12 05:01 PM
04/21/12 05:01 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
3.5 lock to lock is the same, ergo ratio is the same.
Re: Holy Crap! Check this out! [Re: Supercuda] #1219658
04/24/12 03:06 AM
04/24/12 03:06 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I don't know what passes inspection in your districts, but a weld on any steering component here is an automatic "fail". Actually, it's serious enough that a welder can have all of their credentials taken away.
Before considering this item, check your local regulations first.
Mo' Farts
Moderated by "tbagger".
Re: Holy Crap! Check this out! [Re: Grizzly] #1219659
04/24/12 03:36 AM
04/24/12 03:36 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
Is this thing supposed to be a direct fit for Power OR manual steering columns?
NOT that I am interested. They just failed to mention it in the ad. PLUS, $750...??? You can take a POS from the junkyard, spend $350 for a Firm Feel rebuild, add Fast Ratio idler and pitman arms for another $250, and have 12 to 1 ratio for $100 less.
Jeff
Re: Holy Crap! Check this out! [Re: Jjs72D] #1219660
04/24/12 04:22 AM
04/24/12 04:22 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Jeff
For only $100 more, IMHO you are getting a brand new box and lighter weight. It's faster ratio than stock. And to some a better all around ratio. Seems like many sporty new cars have around 14:1 steering.
The long arm method doesn't work with certain headers in some cars. No A-body will work with long pitman and headers at all.
Also the Delphi box is lighter. And it's NEW. Not rebuilt.
I heard this was being worked on a 1 1/2 years ago from someone. Glad it came out. Sort of bummer on the price.
I specifically asked Borgeson at the SEMA show last November about adapting a Dephi box to a Mopar... They said they had no plans. But that was just one of the guys in the both. And probably can't show all thier cards.
I think the 3.5 turns lock to lock is mis-information.
Fact is the Dephi box is 14:1. The Mopar box it 16:1
Dephi also makes a 12:1 or around that box. IIRC, it's the same casting/body as the 14:1 box. So that could/should be in the future.
The welding doesn't concern me as much as the what looks to be lack of gussets and support between the plate and the output shaft tube. The regular Delphi boxes have a long output shaft tube.
It's nice that they designed it using the stock pitman (or any stock pitman). That lowers the cost when it wears out needing replacement.
Re: Holy Crap! Check this out! [Re: autoxcuda] #1219661
04/24/12 10:09 PM
04/24/12 10:09 PM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
They reported it as a remanufactured unit.
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: Holy Crap! Check this out! [Re: autoxcuda] #1219662
04/25/12 07:02 AM
04/25/12 07:02 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
I wonder how much it will clear the engine in a Dart with a newerstyle Hemi in it.
Re: Holy Crap! Check this out! [Re: Grizzly] #1219663
04/25/12 11:46 AM
04/25/12 11:46 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
thats not the only weld either
Re: Holy Crap! Check this out! [Re: HotRodDave] #1219664
04/25/12 12:04 PM
04/25/12 12:04 PM
WV.
Challenger_Nut Offline
WV.
The price is RIDICULOUS!!!!
Re: Holy Crap! Check this out! [Re: Challenger_Nut] #1219665
04/25/12 01:45 PM
04/25/12 01:45 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The fast ratio (12.7:1 vs 14:1) alternative is $100 less (~15%). Also the Delphi unit is much lighter and might give you better header clearance. Lets see one in a car; clearance might be worse. Also the fast ratio alternative will not fit a significant number of cars.
I'd like to see better support between the mounting plate and output housing.
Re: Holy Crap! Check this out! [Re: HotRodDave] #1219666
04/25/12 03:40 PM
04/25/12 03:40 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Yup. Looks like something some backyard mechanic put together with JB Weld after smokin' a big fat Marley. This has to be some kind of a joke.
Happy Birthday there, Big Guy!
Mo' Farts
Re: Holy Crap! Check this out! [Re: Grizzly] #1219667
04/25/12 04:10 PM
04/25/12 04:10 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Borgeson has been converting boxes for 55-57 Chevies for over twenty years, Mustang boxes for about seven years... Everyone I've known that has bought on has been very happy so I can assure you it's not a joke... I have one of their Mustang boxes in my Falcon, it's the best option available for that application IMO... Likely the Mopar box won't be well received because from what I've seen very few aftermarket upgrades are... If you have a better steering box option spend the money to bring it to market & we'll vote with our wallets...
Re: Holy Crap! Check this out! [Re: 1_WILD_RT] #1219668
04/25/12 04:15 PM
04/25/12 04:15 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Delphi is good s##t! I agree, what are your other options? Im glad to see someone ATTEMPTING a better box that bolts in. I guess its better and more cost effective to convert the whole front end over to a rack setup to get power steering and Big Blocks as well as Gen III Hemi to work in A bodies......
Mopar to the bone!!!
Re: Holy Crap! Check this out! [Re: 1_WILD_RT] #1219669
04/25/12 04:28 PM
04/25/12 04:28 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
How much did the Falcon box cost you?
What do they retail for?
Re: Holy Crap! Check this out! [Re: Supercuda] #1219670
04/25/12 04:59 PM
04/25/12 04:59 PM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
That picture doesn't show if there is the crucial THIRD bolt position to the left of the sector. Without it, this thing is worthless. It would be nice to see another angle.
Page 1 of 3 1 2 3
