Need help.....engine no start. Long but necessary. #1218570
04/19/12 04:26 AM
04/19/12 04:26 AM
B-low, N.Y.
JLDUSTER Offline OP
JLDUSTER  Offline OP
B-low, N.Y.
Hello everyone. Have a 360(.030)w/msd billet dist, coil, and digital 6 plus box. Rear mounted batt, 10.5/1 comp. running c12, w/demon 750 carb. While trying to boost wifes van w/my batt., put charger on my batt. Tried to start my car, batt low. Replaced batt. After numerous tries (pumping gas thinking it was flooded)still no start. Found faulty ign toggle & replaced. By now have tried to start 20x or so. Starter seems to be turning slower than normal. Voltage from 12.4 drops to 8 at cranking. Could cyl be full of gas? No gas smell, pulled plugs & spun over...still seemed a tad slow. Tested for spark ok. Checkedpickup in dist(579ohms).Any ideas? Appreciate any help or thoughts. Thank you.
Re: Need help.....engine no start. Long but necessary. [Re: JLDUSTER] #1218571
04/19/12 09:14 AM
04/19/12 09:14 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
I doubt the MSD is firing at 8 volts while cranking. I would suggest charging the battery, checking for spark by pulling one of the plug wires and install a spare plug in it and resting it on a bare portion of the engine or frame and note if there is a spark when cranking. Gotta have air, fuel, compression and spark to make it all happen.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Need help.....engine no start. Long but necessary. [Re: Dads426] #1218572
04/19/12 09:52 AM
04/19/12 09:52 AM
B-low, N.Y.
JLDUSTER Offline OP
JLDUSTER  Offline OP
B-low, N.Y.
Dads426-checked for spark already at coil and at plugs with spark plug tester..tested fine. Seems like engine not spinning fast enough. Only change was trying to boost wifes van...after that ign toggle was burned out and engine ground melted(replaced both). Also starter cable from trunk was warm to touch after repeated cranks.
Re: Need help.....engine no start. Long but necessary. [Re: JLDUSTER] #1218573
04/19/12 10:15 AM
04/19/12 10:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The starter sounds like its drawing alot of amps..
but if you have spark at the plugs it should still
fire... have you pumped the throttle on the carb to
see if your getting fuel(and smell it to make sure its
gas)... if need be spray some starter fluid in it to
see if it hits
Re: Need help.....engine no start. Long but necessary. [Re: MR_P_BODY] #1218574
04/19/12 10:21 AM
04/19/12 10:21 AM
B-low, N.Y.
JLDUSTER Offline OP
JLDUSTER  Offline OP
B-low, N.Y.
Mr_P_Body-yes plenty of fuel. Mini starter is over 16 yrs old tho. Car had sat for 9 months.
Re: Need help.....engine no start. Long but necessary. [Re: JLDUSTER] #1218575
04/19/12 10:26 AM
04/19/12 10:26 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You said you dont smell gas... if you've been cranking
it that much you SHOULD be flooded... but you still
dont smell gas... sounds like its old fuel
Re: Need help.....engine no start. Long but necessary. [Re: MR_P_BODY] #1218576
04/19/12 10:28 AM
04/19/12 10:28 AM
B-low, N.Y.
JLDUSTER Offline OP
JLDUSTER  Offline OP
B-low, N.Y.
Mr P Body- meant to say didnt smell gas in oil! Drained cell cleaned and refilled.
Re: Need help.....engine no start. Long but necessary. [Re: JLDUSTER] #1218577
04/19/12 10:37 AM
04/19/12 10:37 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Well if your getting fuel... and spark(we will assume
you are getting air) so its time to check compression
Re: Need help.....engine no start. Long but necessary. [Re: JLDUSTER] #1218578
04/19/12 10:37 AM
04/19/12 10:37 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
While you'd like to see more than 8 w/ MSD I'm going to bet your gas is bad. Unless you used some gas stabilizer it's done. If you still have the stock or metal tank you probably have water in the mix too. I'd drain the tank and clean the line out. You can try and gravity feed the carb from a can of new gas to see if that's the problem before you go thru it all.
Coming soon!!!!
Re: Need help.....engine no start. Long but necessary. [Re: MR_P_BODY] #1218579
04/19/12 10:40 AM
04/19/12 10:40 AM
B-low, N.Y.
JLDUSTER Offline OP
JLDUSTER  Offline OP
B-low, N.Y.
Mr Yuck/Mr P Body...drained cell and cleaned..replaced fuel with 100 octane from Delta Sonic(it was closer). Possible bad gas from station? Do you thimk the starter is an issue? Car started fine before put away. Just concerned when push start button voltage drops to 8v. Thank you for your help!
Re: Need help.....engine no start. Long but necessary. [Re: JLDUSTER] #1218580
04/19/12 10:45 AM
04/19/12 10:45 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes I would think its drawing a LOT of amps... that
is pulling power away from the ignition.. I would
have a charger on it or jumper cables when trying
to start it.... when you checked spark was it a nice
blue color or yellow
Re: Need help.....engine no start. Long but necessary. [Re: MR_P_BODY] #1218581
04/19/12 10:48 AM
04/19/12 10:48 AM
B-low, N.Y.
JLDUSTER Offline OP
JLDUSTER  Offline OP
B-low, N.Y.
Mr P Body- yellow-orangish on ign tester. Have had charger and have had fresh booster battery...still drops to 8v at cranking.
Re: Need help.....engine no start. Long but necessary. [Re: JLDUSTER] #1218582
04/19/12 10:53 AM
04/19/12 10:53 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Sounds like your starter is bad... drawing way too
many amps and its slow cranking... like I said...
that is pulling power from the ignition... you can
do a draw test if you have a big amp gauge OR pull
it off and have a parts store test it
Re: Need help.....engine no start. Long but necessary. [Re: MR_P_BODY] #1218583
04/19/12 10:55 AM
04/19/12 10:55 AM
B-low, N.Y.
JLDUSTER Offline OP
JLDUSTER  Offline OP
B-low, N.Y.
Back to work today...will pull off Monday. Thank everyone for their help. I will not let this thing beat me!
Re: Need help.....engine no start. Long but necessary. [Re: JLDUSTER] #1218584
04/19/12 11:30 AM
04/19/12 11:30 AM
Shingle Springs Ca
haddixj Offline
haddixj  Offline
Shingle Springs Ca
Check your battery connections. Sounds like the only thing that has changed is you removed the battery. They may look fine on the outside but bad on the inside. Are the cables hot when you crank it over?
70 duster 25.1E,73 barracuda, 70 gran coupe, 71 cuda
Re: Need help.....engine no start. Long but necessary. [Re: haddixj] #1218585
04/19/12 12:29 PM
04/19/12 12:29 PM
B-low, N.Y.
JLDUSTER Offline OP
JLDUSTER  Offline OP
B-low, N.Y.
haddixj-yes...cable from master disconnect on tailpanel to starter very warm after repeated cranking.
Re: Need help.....engine no start. Long but necessary. [Re: JLDUSTER] #1218586
04/19/12 02:31 PM
04/19/12 02:31 PM
Check the voltage on both sides of the cut off switch, static first and then cranking. I had a cut off switch go bad, it melted two of the battery termainals due to slow cranking on the starter
Re: Need help.....engine no start. Long but necessary. [Re: Cab_Burge] #1218587
04/19/12 03:10 PM
04/19/12 03:10 PM
B-low, N.Y.
JLDUSTER Offline OP
JLDUSTER  Offline OP
B-low, N.Y.
Will check tomorrow. Thanks!
