Re: Another what will it run?SB
[Re: justinp61]
#1217095
04/16/12 11:04 PM
04/16/12 11:04 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
I guess it depends on the driver. 14's ????? Just kidding. Hopefully into the 11's
[Re: Crizila]
#1217097
04/16/12 11:37 PM
04/16/12 11:37 PM
Posts: 6,147 Melbourne , Australia
LA360
I'd run a 8" converter with around a 5K stall speed. With your current deal, I would expect a mid to high 11 second pass. If they are Mickey Thompson 28" x 9" slicks, they are only around 27" in diameter.
Alan Jones
[Re: reknapp52]
#1217101
04/17/12 03:34 PM
04/17/12 03:34 PM
Posts: 214 Colo Springs, CO
DconD100
Colo Springs, CO
That's the exact cam in my 408, my Eddie's flow 280, and it made 578 hp @ 6200rpm. Should run low, low 11's in a 360 at that weight!
Pump Gas Small Blocks Rock!
11.53 @ 116mph E85 408 at 8500 ft da,
3605 pound truck, 3.91s, street driven
[Re: mopartuner]
#1217104
04/17/12 05:50 PM
04/17/12 05:50 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
My Duster ran 11 teens to 20's with a similiar set up but with W2's that flowed comparably. I used a 4600 T/A converter and 4.56's, shifted it at about 7200.
[Re: Guitar Jones]
#1217105
04/17/12 06:43 PM
04/17/12 06:43 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
That combo is very close to mine, my cam is smaller and i run a 4.10 gear last time out was the first time i was able to make laps in the car, without braking something, and went 7.14 1/8 off the throttle track was to wet to run 1/4 that day, and i think i have plenty more.
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: RobX4406]
#1217107
04/17/12 07:51 PM
04/17/12 07:51 PM
Posts: 3,210 robin hood country
deaks
robin hood country
As is 11.50 at 119 mph, with a 5k+ converter 11 teens. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
