Another what will it run?SB #1217088
04/16/12 07:18 PM
04/16/12 07:18 PM
ont,canada
mopartuner Offline OP
ont,canada
Motor is 365 ci with KB-107 slugs 10.75 Comp(est)180psi cyl Ported Eddys(flow app.275 cfm)Victor 340 intake,2" open spacer with a 750 holley/proform carb.The cam will be a hughes solid flat tappet htl 5665as (614/626 lift 256/260 dur @.050 103 intake centerline)Car is 3100# with the driver.Trans is a 904 with low 1st gear and a 3800 converter.Rear is a 8-3/4 with 410 gears and a 9x28 slick.Car has 3000# SS springs w/snubber.I footbrake and the car usually works well.What do you folks think it will do?
Re: Another what will it run?SB [Re: mopartuner] #1217089
04/16/12 08:31 PM
04/16/12 08:31 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
12.2's
Re: Another what will it run?SB [Re: mcat4321] #1217090
04/16/12 08:58 PM
04/16/12 08:58 PM
PA
moparacer Offline
moparacer  Offline
PA
A body?
Should run low 11s with that setup.
Re: Another what will it run?SB [Re: moparacer] #1217091
04/16/12 09:02 PM
04/16/12 09:02 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yeah another mid-low 11's here
Coming soon!!!!
Re: Another what will it run?SB [Re: moparacer] #1217092
04/16/12 09:05 PM
04/16/12 09:05 PM
Mississippi Gulf Coast
Mroctober Offline
Mroctober  Offline
A body?
11.20s with 488 gears
Re: Another what will it run?SB [Re: Mroctober] #1217093
04/16/12 09:35 PM
04/16/12 09:35 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Ill guess high 11 low 12. Needs 4.56 or 4.88 gear. What ya plan on shifting at? I imagine this motor gonna power peak at 6800.
Re: Another what will it run?SB [Re: mopartuner] #1217094
04/16/12 10:53 PM
04/16/12 10:53 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
11 teens - low twenties if it leaves well.
Re: Another what will it run?SB [Re: justinp61] #1217095
04/16/12 11:04 PM
04/16/12 11:04 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
I guess it depends on the driver.
14's ?????
Just kidding.
Hopefully into the 11's
Re: Another what will it run?SB [Re: mopartuner] #1217096
04/16/12 11:14 PM
04/16/12 11:14 PM
Az
Crizila Offline
Crizila  Offline
Az
11.45 @ 117.50
Fastest 300
Re: Another what will it run?SB [Re: Crizila] #1217097
04/16/12 11:37 PM
04/16/12 11:37 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I'd run a 8" converter with around a 5K stall speed. With your current deal, I would expect a mid to high 11 second pass. If they are Mickey Thompson 28" x 9" slicks, they are only around 27" in diameter.
Alan Jones
Re: Another what will it run?SB [Re: Kam*Kuda] #1217098
04/17/12 03:05 PM
04/17/12 03:05 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
oh please keep us updated... im pretty sure im not far off with my guess , these low 11 guys are lets say being a little kind...
Re: Another what will it run?SB [Re: mcat4321] #1217099
04/17/12 03:15 PM
04/17/12 03:15 PM
Renton Washington
Triple Threat Offline
Renton Washington
11.40
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Another what will it run?SB [Re: Triple Threat] #1217100
04/17/12 03:23 PM
04/17/12 03:23 PM
Cascade, CO
reknapp52 Offline
reknapp52  Offline
Cascade, CO
I'll guess 11.60s.
Re: Another what will it run?SB [Re: reknapp52] #1217101
04/17/12 03:34 PM
04/17/12 03:34 PM
Colo Springs, CO
DconD100 Offline
DconD100  Offline
Colo Springs, CO
That's the exact cam in my 408, my Eddie's flow 280, and it made 578 hp @ 6200rpm. Should run low, low 11's in a 360 at that weight!
Pump Gas Small Blocks Rock! 11.53 @ 116mph E85 408 at 8500 ft da, 3605 pound truck, 3.91s, street driven
Re: Another what will it run?SB [Re: DconD100] #1217102
04/17/12 03:46 PM
04/17/12 03:46 PM
Ohio
aquamist60 Offline
aquamist60  Offline
Ohio
I'm thinking 11:00's tp 11:20's
Re: Another what will it run?SB [Re: aquamist60] #1217103
04/17/12 05:43 PM
04/17/12 05:43 PM
ont,canada
ont,canada
I will update once the changes are done and we make some runs at the track.I would be happy with 11.40 lets hope it can get it done.As for the 12.2 prediction, boy I hope not.........the car runs 12.05 with OOTB Eddies and a 520 lift hyd cam so it better not run slower!Thanks for the replies.....now back out to the shop,I have some heads to finish up!
Re: Another what will it run?SB [Re: mopartuner] #1217104
04/17/12 05:50 PM
04/17/12 05:50 PM
Guitar Jones Offline
My Duster ran 11 teens to 20's with a similiar set up but with W2's that flowed comparably. I used a 4600 T/A converter and 4.56's, shifted it at about 7200.
Re: Another what will it run?SB [Re: Guitar Jones] #1217105
04/17/12 06:43 PM
04/17/12 06:43 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
That combo is very close to mine, my cam is smaller and i run a 4.10 gear last time out was the first time i was able to make laps in the car, without braking something, and went 7.14 1/8 off the throttle track was to wet to run 1/4 that day, and i think i have plenty more.
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: Another what will it run?SB [Re: 65signet] #1217106
04/17/12 07:35 PM
04/17/12 07:35 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Converter is going to be the biggest drawback.
It should have some big MPH for the et. Like 11.40 at 123+ is my guess
Re: Another what will it run?SB [Re: RobX4406] #1217107
04/17/12 07:51 PM
04/17/12 07:51 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
As is 11.50 at 119 mph, with a 5k+ converter 11 teens.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
