Identifying BB 727 #1215802
04/14/12 09:45 PM
04/14/12 09:45 PM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
A friend of mine has several 727's laying around and not sure what they were behind. How can I tell a BB trans from a SB or /6 trans?
Re: Identifying BB 727 [Re: elmor] #1215803
04/14/12 10:22 PM
04/14/12 10:22 PM
33950
67Monaco Offline
67Monaco  Offline
33950
The bell housing and where the starter mounts will be the most superficial way to tell.
Re: Identifying BB 727 [Re: 67Monaco] #1215804
04/14/12 11:09 PM
04/14/12 11:09 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
also look on the drivers side,above the trans pan rail,there is a PK# stamped there....will id the year and engine the trans came from,also look for the 68 only VIN stamped on the top of the bellhousing, and the 69 andup VIN stamped on the pass side ID boss....I went to a guys house and he said take your pick of 727B trans for 100.00,grabbed 1,turned out it was a 71 440+6 trans...
Re: Identifying BB 727 [Re: Joesixpack] #1215805
04/15/12 08:33 AM
04/15/12 08:33 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
look at the top 2 bolt holes. The BB trans holes are 6 1/2" apart.. The SB holes are 7 1/2" apart..
I am truckless..
Re: Identifying BB 727 [Re: 340SHORTY] #1215806
04/15/12 09:09 AM
04/15/12 09:09 AM
moparx Offline
moparx  Offline
you don't even need a tape measure. look at the starter nose boss....... the big block is in line with the input shaft. the small block nose boss is at about the 4 o'clock position.[ i can't tell time very good ! ]
Re: Identifying BB 727 [Re: moparx] #1215807
04/15/12 04:28 PM
04/15/12 04:28 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Yep, quick and dirty
BB 3:00
SB 4:00
Re: Identifying BB 727 [Re: elmor] #1215808
04/16/12 05:21 PM
04/16/12 05:21 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The bottom four bolt holes are the easiest way to tell, the BB has four equal size small holes and the SB has two small holes near the center with two larger outboard of them.
Re: Identifying BB 727 [Re: John_Kunkel] #1215809
04/16/12 07:59 PM
04/16/12 07:59 PM
dogdays Offline
dogdays  Offline
Thanks, JK! That's so easy I'll probably remember it.
R.
Re: Identifying BB 727 [Re: dogdays] #1215810
04/17/12 04:26 AM
04/17/12 04:26 AM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
Thanks guys. My buddy has 6 or 7 trans laying around. Now I can figure out which one I need to grab. He's got one that all the forward gears worked perfect, but reverse is gone. I know that one's a big block. It came out of a pickup with a 400. Guess I'd better get me a service manual.
