Re: Identifying BB 727
[Re: Joesixpack]
#1215805
04/15/12 08:33 AM
04/15/12 08:33 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
look at the top 2 bolt holes. The BB trans holes are 6 1/2" apart.. The SB holes are 7 1/2" apart..
I am truckless..
[Re: moparx]
#1215807
04/15/12 04:28 PM
04/15/12 04:28 PM
Posts: 2,111 Bowie, MD
Reggie
Bowie, MD
you don't even need a tape measure. look at the starter nose boss....... the big block is in line with the input shaft. the small block nose boss is at about the 4 o'clock position.[ i can't tell time very good ! ]
Yep, quick and dirty
BB 3:00 SB 4:00
[Re: elmor]
#1215808
04/16/12 05:21 PM
04/16/12 05:21 PM
Posts: 25,842 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The bottom four bolt holes are the easiest way to tell, the BB has four equal size small holes and the SB has two small holes near the center with two larger outboard of them.
