63 savoy max wedge hood scoop holes HELP!!!! #1214577
04/12/12 12:11 AM
04/12/12 12:11 AM
south central nebraska
GI Moparman Offline OP
Im building a 63 plymouth into a max wedge clone and wondering if anyone can help with the location of the two holes that need to be in the hood under the scoop. Also the location of how far the rear of the scoop should be from the back of the hood. I need the size of the holes and the location and would appriciate greatly any help. Thanks Guys! Without moparts and its vast knowledge what would our mopars look like?
Re: 63 savoy max wedge hood scoop holes HELP!!!! [Re: GI Moparman] #1214578
04/12/12 12:29 AM
04/12/12 12:29 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Maybe this will help?
Re: 63 savoy max wedge hood scoop holes HELP!!!! [Re: 70440+6bbl] #1214579
04/12/12 12:32 AM
04/12/12 12:32 AM
That definatly gives me an awsome idea what it will look like! Thanks but any measurements?
Re: 63 savoy max wedge hood scoop holes HELP!!!! [Re: GI Moparman] #1214580
04/12/12 09:46 AM
04/12/12 09:46 AM
Helsinki, Finland
Anselmi Offline
Anselmi  Offline
Helsinki, Finland
I would do it this way -> http://www.moparmax.com/tech/2007/ii_12-string-1.html ...if you want the holes right above the carbs. If you are using later model K-member or "different" motor mounts, the original holes would not probably match anyway.
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: 63 savoy max wedge hood scoop holes HELP!!!! [Re: GI Moparman] #1214581
04/12/12 10:44 AM
04/12/12 10:44 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Sorry, I don't have the measurements. Contact member QuickSilver (he made the hood and scoop), and perhaps he can give you what you need.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: 63 savoy max wedge hood scoop holes HELP!!!! [Re: GI Moparman] #1214582
04/12/12 03:25 PM
04/12/12 03:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
For the hole centers I always install some 1/4" all-thread in the carbs just long enough to touch the inside of the hood when closed (grind the top to a point) and gently close the hood on the pointed end. Smack the top of the hood with your fist to leave a couple of dimples in the paint and that's center.
Re: 63 savoy max wedge hood scoop holes HELP!!!! [Re: John_Kunkel] #1214583
04/12/12 05:30 PM
04/12/12 05:30 PM
Almost Heaven
B_Body_Bob Offline
Master of nothing
B_Body_Bob  Offline
Master of nothing
Almost Heaven
There's a Steve Magnante article on moparmax.com explaining how he did it on an AWB Dart build, if you can find it. I found the rest of the article, but not that part. It's described in his "how to build AWB cars" book too.
Everybody makes fun of a hillbilly until they need something fixed
