Whats my next step for solving my light-throttle surge?
#1207100
03/31/12 06:06 PM
03/31/12 06:06 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
Awhile ago when I first installed my Carter AVS, I had an off-the-line stumble that ended up being mostly solved by going back to the original rubber accelerator pump.
I'm still having a problem with a very light throttle surge at very low RPM, with the rpm audibly wavering up and down just a bit unless I give it more gas when cruising at around 25-35. Today I tried opening up the idle mixture screws another 3/4 turn each and it didn't make a difference. Before I sent my whole dizzy off to FBO I tried fiddling with the vacuum advance and it didn't really change anything.
I've read some people recommend a couple of small holes in the throttle blades to allow the idle circuit to work better - would this be a good thing to try it if seems to be free of any misbehavior everywhere else in the driving range? If I try getting the engine warm and then turning down the idle as far as can in drive and it seems better, might this be a solution?
I've also read about drilling out the idle compensators, but I don't want to go buying a set of wee drill bits and yet another gasket set for this thing if I can do something simpler first.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Whats my next step for solving my light-throttle surge?
[Re: rbstroker]
#1207102
03/31/12 06:22 PM
03/31/12 06:22 PM
Secret Chimp
Eugene, Oregon
Yes, this only happened after changing the carb. This is for my 318 wagon in my sig.
[Re: Secret Chimp]
#1207105
03/31/12 07:36 PM
03/31/12 07:36 PM
Posts: 4,848 Memphis
HemiRick
Memphis
I agree lean and to fix this properly you need some smaller diameter metering rods.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: topside]
#1207107
03/31/12 07:42 PM
03/31/12 07:42 PM
Secret Chimp
Eugene, Oregon
Couldn't I be lean in just the idle circuit though? This doesn't happen unless I'm just within the first crack of the throttle to maintain speed on a slight grade in town. Everywhere else it doesn't stumble or surge at all.
[Re: Secret Chimp]
#1207111
04/01/12 08:49 AM
04/01/12 08:49 AM
Posts: 5,048 Atlanta Indiana
Dave Watt
Atlanta Indiana
Since you are driving down the road when it's happening, the carburetor is now using the primary jetting. Try going one step larger on the primary jets and the lean surge should go away.
[Re: Secret Chimp]
#1207114
04/01/12 04:06 PM
04/01/12 04:06 PM
RapidRobert
next larger jet(s) in your strip kit. a .003" larger jet is a much richer change than a .003" smaller rod
[Re: Secret Chimp]
#1207115
04/01/12 04:51 PM
04/01/12 04:51 PM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
In drive it's around 12.
What spring do you have in the primary wells ? Do you have the B rock tuning kit with jets rods and springs ? or just the spring kit ? What carb is this the one you got off ebarf ?
[Re: lewtot184]
#1207116
04/01/12 05:19 PM
04/01/12 05:19 PM
Posts: 3,916 usa
lewtot184
usa
enlarge the idle feed tube orifice in the primary clusters.
i guess you folks don't understand this, .
[Re: lewtot184]
#1207117
04/01/12 11:29 PM
04/01/12 11:29 PM
JohnRR
U.S.S.A.
He is using a factory stock 440 carb on his 318 , I'd change the step springs before modifying things , but that's me ...
[Re: JohnRR]
#1207118
04/02/12 12:17 AM
04/02/12 12:17 AM
Secret Chimp
Eugene, Oregon
It's a Carter AVS 4966S. I haven't touched any of the internals, including the springs. If nobody previously changed the primary jetting, it has .089 primaries with .066/.063/.058 metering rods. I'm not sure if Edelbrock springs work with the long AVS metering rods or if I'd need to convert to Edelbrock jets and rods (and use flat covers) first.
[Re: Secret Chimp]
#1207119
04/02/12 12:54 AM
04/02/12 12:54 AM
JohnRR
U.S.S.A.
ebrock springs should work , travel is limited by the cap , it has to be right for the number of steps on the rod .
With 12 you are below stock vacuum , so trying a spring change to one for that rated vacuum would be a good idea .
[Re: JohnRR]
#1207120
04/02/12 10:21 AM
04/02/12 10:21 AM
Posts: 3,916 usa
lewtot184
usa
i know, but why would you go after the main metering for an off idle problem?
[Re: Secret Chimp]
#1207121
04/02/12 10:35 AM
04/02/12 10:35 AM
Posts: 1,357 central Florida
VL21
central Florida
This is just a shot in the dark, have had it before. Are you running a vacuum advance? If so, do you have it connected to ported or manifold vacuum source? I have had manifold vacuum under light or no throttle advance the timing so far it would cause something like your symptoms. Just a thought.
It takes gasoline to interest me.
[Re: lewtot184]
#1207122
04/02/12 10:39 AM
04/02/12 10:39 AM
JohnRR
U.S.S.A.
It doesn't sound like an off idle problem to me , but what do I know
