Whats my next step for solving my light-throttle surge? #1207100
03/31/12 06:06 PM
03/31/12 06:06 PM
Eugene, Oregon
Secret Chimp Offline OP
Eugene, Oregon
Awhile ago when I first installed my Carter AVS, I had an off-the-line stumble that ended up being mostly solved by going back to the original rubber accelerator pump.
I'm still having a problem with a very light throttle surge at very low RPM, with the rpm audibly wavering up and down just a bit unless I give it more gas when cruising at around 25-35. Today I tried opening up the idle mixture screws another 3/4 turn each and it didn't make a difference. Before I sent my whole dizzy off to FBO I tried fiddling with the vacuum advance and it didn't really change anything.
I've read some people recommend a couple of small holes in the throttle blades to allow the idle circuit to work better - would this be a good thing to try it if seems to be free of any misbehavior everywhere else in the driving range? If I try getting the engine warm and then turning down the idle as far as can in drive and it seems better, might this be a solution?
I've also read about drilling out the idle compensators, but I don't want to go buying a set of wee drill bits and yet another gasket set for this thing if I can do something simpler first.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Whats my next step for solving my light-throttle surge? [Re: Secret Chimp] #1207101
03/31/12 06:12 PM
03/31/12 06:12 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Was everything good before changing the carb? Any other changes whatsoever? What engine?
Re: Whats my next step for solving my light-throttle surge? [Re: rbstroker] #1207102
03/31/12 06:22 PM
03/31/12 06:22 PM
Eugene, Oregon
Eugene, Oregon
Yes, this only happened after changing the carb. This is for my 318 wagon in my sig.
Re: Whats my next step for solving my light-throttle surge? [Re: Secret Chimp] #1207103
03/31/12 07:24 PM
03/31/12 07:24 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Are you running vacuum advance? If so try disconecting the hose from the distributor(plug hose so no vacuum leak) and test drive. Sometimes too much advance will cause a surge. If this cures the surge you may be able to adjust the vacuum advance with a allen wrench.
Re: Whats my next step for solving my light-throttle surge? [Re: Ply72rr] #1207104
03/31/12 07:29 PM
03/31/12 07:29 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
You are lean....
Re: Whats my next step for solving my light-throttle surge? [Re: Secret Chimp] #1207105
03/31/12 07:36 PM
03/31/12 07:36 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I agree lean and to fix this properly you need some smaller diameter metering rods.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Whats my next step for solving my light-throttle surge? [Re: HemiRick] #1207106
03/31/12 07:39 PM
03/31/12 07:39 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Assuming timing & fuel pressure are good, no restrictions in fuel lines:
Metering rods as HemiRick says
More jet
Less timing
Re: Whats my next step for solving my light-throttle surge? [Re: topside] #1207107
03/31/12 07:42 PM
03/31/12 07:42 PM
Eugene, Oregon
Eugene, Oregon
Couldn't I be lean in just the idle circuit though? This doesn't happen unless I'm just within the first crack of the throttle to maintain speed on a slight grade in town. Everywhere else it doesn't stumble or surge at all.
Re: Whats my next step for solving my light-throttle surge? [Re: Secret Chimp] #1207108
03/31/12 08:32 PM
03/31/12 08:32 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
enlarge the idle feed tube orifice in the primary clusters.
Re: Whats my next step for solving my light-throttle surge? [Re: Secret Chimp] #1207109
04/01/12 02:37 AM
04/01/12 02:37 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
If the jetting is correct, try a different step-up spring.
Re: Whats my next step for solving my light-throttle surge? [Re: 451Mopar] #1207110
04/01/12 08:14 AM
04/01/12 08:14 AM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
last time my dart did that it was because it was lean on the primary side of the carb. i ended up going two sizes fatter on the primaries and it straightened right out. only thing i changed at the time was the exhaust system.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Whats my next step for solving my light-throttle surge? [Re: Secret Chimp] #1207111
04/01/12 08:49 AM
04/01/12 08:49 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Since you are driving down the road when it's happening, the carburetor is now using the primary jetting. Try going one step larger on the primary jets and the lean surge should go away.
Re: Whats my next step for solving my light-throttle surge? [Re: Secret Chimp] #1207112
04/01/12 10:43 AM
04/01/12 10:43 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
What is your engine vacuum at idle , you may need to change the step up springs on the primary jets to a lighter spring.
Re: Whats my next step for solving my light-throttle surge? [Re: JohnRR] #1207113
04/01/12 03:10 PM
04/01/12 03:10 PM
Eugene, Oregon
Eugene, Oregon
In drive it's around 12.
Re: Whats my next step for solving my light-throttle surge? [Re: Secret Chimp] #1207114
04/01/12 04:06 PM
04/01/12 04:06 PM
next larger jet(s) in your strip kit. a .003" larger jet is a much richer change than a .003" smaller rod
Re: Whats my next step for solving my light-throttle surge? [Re: Secret Chimp] #1207115
04/01/12 04:51 PM
04/01/12 04:51 PM
JohnRR Offline
JohnRR  Offline
What spring do you have in the primary wells ? Do you have the B rock tuning kit with jets rods and springs ? or just the spring kit ? What carb is this the one you got off ebarf ?
Re: Whats my next step for solving my light-throttle surge? [Re: lewtot184] #1207116
04/01/12 05:19 PM
04/01/12 05:19 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i guess you folks don't understand this, .
Re: Whats my next step for solving my light-throttle surge? [Re: lewtot184] #1207117
04/01/12 11:29 PM
04/01/12 11:29 PM
JohnRR Offline
JohnRR  Offline
He is using a factory stock 440 carb on his 318 , I'd change the step springs before modifying things , but that's me ...
Re: Whats my next step for solving my light-throttle surge? [Re: JohnRR] #1207118
04/02/12 12:17 AM
04/02/12 12:17 AM
Eugene, Oregon
Eugene, Oregon
It's a Carter AVS 4966S. I haven't touched any of the internals, including the springs. If nobody previously changed the primary jetting, it has .089 primaries with .066/.063/.058 metering rods. I'm not sure if Edelbrock springs work with the long AVS metering rods or if I'd need to convert to Edelbrock jets and rods (and use flat covers) first.
Re: Whats my next step for solving my light-throttle surge? [Re: Secret Chimp] #1207119
04/02/12 12:54 AM
04/02/12 12:54 AM
JohnRR Offline
JohnRR  Offline
ebrock springs should work , travel is limited by the cap , it has to be right for the number of steps on the rod .
With 12 you are below stock vacuum , so trying a spring change to one for that rated vacuum would be a good idea .
