Help! Front Runner Tire Size #1206134
03/29/12 08:42 PM
03/29/12 08:42 PM
Harrison, NY
Classic Car Guy Offline OP
Harrison, NY
Hi Guy's....
How does the front Tire size affect the ET and or MPH? Example.. I had 27" M/T 4 ply street type skinny and the Moroso 26" track only skinny? Does the height affect the roll out, ET or MPH? Not sure what to purchase. Thanks, Joe
Some of the Ride's...... 58 Ply Fury "Christine" Admin of: [url=http://www.ChristineCarClub.com]www.ChristineCarClub.com[/url 65 Ply Satellite [Email]9.43@141[/Email] 64 50th anniv 880 Custom 2dht 383 All Pwr. I'd Rather Be Hated For The Person I Am, Than Loved For The Person I Am Not!!!
Re: Help! Front Runner Tire Size [Re: Classic Car Guy] #1206135
03/29/12 09:33 PM
03/29/12 09:33 PM
The front tire size can affect all three things, reaction time, ET and MPH One inch is not much but it should be measurable I have ran all the way from 22 inch front tall tires to 31 inch tall and most sizes in between If your going to bracket race it or class race the car on a sportmans tree(.500 seconds between each light) I would use the tallest tire you can fit on the car If your going to run on a Pro Tree(.400) and use electronics it doesn't matter what size front tire is on the car, you can dial in the delay box for the reaction times
Re: Help! Front Runner Tire Size [Re: Classic Car Guy] #1206136
03/30/12 08:59 AM
03/30/12 08:59 AM
an8sec70cuda Offline
Shorter tire = quicker reaction time.
Taller tire = quicker ET due to less rolling resistance, supposedly.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Help! Front Runner Tire Size [Re: an8sec70cuda] #1206137
03/30/12 10:08 AM
03/30/12 10:08 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd think i'd be more of a RT change than ET change...
Coming soon!!!!
Re: Help! Front Runner Tire Size [Re: Mr.Yuck] #1206138
03/30/12 10:16 AM
03/30/12 10:16 AM
I think so too, hence my "supposedly" remark. I was just pointing out the general rule.
CHIP
Re: Help! Front Runner Tire Size [Re: an8sec70cuda] #1206139
03/30/12 12:57 PM
03/30/12 12:57 PM
Ohio
P
pengwin Offline
pengwin  Offline
P
Ohio
In theory, a taller front tire will experience fewer revolutions over a given distance than a shorter tire, which results in less parasitic drag and better ET's.
Re: Help! Front Runner Tire Size [Re: pengwin] #1206140
03/30/12 01:28 PM
03/30/12 01:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A taller tire will result in longer roll out on the
lights giving you a better rolling start which will
end up in a quick ET.... but if your concern is the RT
then the short tire will break the beams sooner
