Page 3 of 4 1 2 3 4
Re: 5" 650 HEMI! Dyno sheet and pictures **MORE PICTURES*** [Re: Adrielp] #1206025
04/03/12 09:31 PM
04/03/12 09:31 PM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
Well I'm sure if Goodwin put the 650 on kill and spun it to 10,000 rpms it would make north of 2000hp. Putting your 550 to shame. It's all relative.
Re: 5" 650 HEMI! Dyno sheet and pictures **MORE PICTURES*** [Re: 7sec.cuda] #1206026
04/03/12 09:41 PM
04/03/12 09:41 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
i just got my 550 cubic inch hemi back from Larry Morgan it made better than 1500hp (at better than 2.8 hp per cubic inch)if he had those kind of parts to work with i would be makin well over 1700 (just sayin) not bustin anybody chops
First off, you have a very impressive engine at max effort 550CI hemi. Just curious, what does it run all out, and what is the weight of the car? 2nd the smaller the motor, the better HP per CI. 3rd Diablo has a less than all out hemi that makes very respectable power while retaining depenability. 4th We'll see how his motor hopfully allows him to win a championship next year. Just sayin.....
Re: 5" 650 HEMI! Dyno sheet and pictures **MORE PICTURES*** [Re: Adrielp] #1206027
04/03/12 09:43 PM
04/03/12 09:43 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
That's easy, its one of the Hemi99 one of two Mopar based engine combinations that can reach that HP level NA.
Just curious....what's the other one?
Re: 5" 650 HEMI! Dyno sheet and pictures **MORE PICTURES*** [Re: WO23Coronet] #1206028
04/04/12 12:31 AM
04/04/12 12:31 AM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
What kind of HEMI? GenII (426), 99 HEMI, or? And what are the rough build specs of it (comp, cam, 2 Dominators, etc)?
7SecCuda has a Hemi 99. I would imagine much like mine, built by someone who builds these on a daily basis, although these days the valve covers say Ford
Re: 5" 650 HEMI! Dyno sheet and pictures **MORE PICTURES*** [Re: Al_Alguire] #1206029
04/04/12 11:39 AM
04/04/12 11:39 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Cant be.....
Re: 5" 650 HEMI! Dyno sheet and pictures **MORE PICTURES*** [Re: Moparnut426] #1206030
04/04/12 11:45 AM
04/04/12 11:45 AM
Las Vegas
Las Vegas
You be the judge..This is the "Ford" pro stock motor. Look familiar
Re: 5" 650 HEMI! Dyno sheet and pictures **MORE PICTURES*** [Re: Al_Alguire] #1206031
04/04/12 12:35 PM
04/04/12 12:35 PM
Moparnut426 Offline
Moparnut426  Offline
Oh I know Al, I wish there was a sarcasim smiley on here. I cant believe he hasnt done better with that Ferd, err Mopar since its been out.
HAHA, If ya look close enough you can almost see the grinder marks from them grinding off the HEMI off the valve cover LOL!!
Re: 5" 650 HEMI! Dyno sheet and pictures **MORE PICTURES*** [Re: Al_Alguire] #1206032
04/04/12 12:58 PM
04/04/12 12:58 PM
Stratford,Ct
7sec.cuda Offline
7sec.cuda  Offline
Stratford,Ct
hey Al i bet u CANT bolt a set of mopar hemi valve covers on that FORD, but if we could that ford would make another 100 hp because it is a better design
Re: 5" 650 HEMI! Dyno sheet and pictures **MORE PICTURES*** [Re: Big B] #1206033
04/04/12 01:00 PM
04/04/12 01:00 PM
Stratford,Ct
7sec.cuda Offline
7sec.cuda  Offline
Stratford,Ct
if i were to swing this thing north of 10,000 all i would have is a basket of pieces
Re: 5" 650 HEMI! Dyno sheet and pictures **MORE PICTURES*** [Re: camastomcat] #1206034
04/04/12 01:01 PM
04/04/12 01:01 PM
Stratford,Ct
7sec.cuda Offline
7sec.cuda  Offline
Stratford,Ct
my signature gives information
Re: 5" 650 HEMI! Dyno sheet and pictures **MORE PICTURES*** [Re: 7sec.cuda] #1206035
04/04/12 01:58 PM
04/04/12 01:58 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Sorry, missed the weight. It factors to 1405HP on the Wallace calculator by ET. I know they are a bit low, so that's very impressive and I'm sure by your ET vs MPH, there's more there.
Re: 5" 650 HEMI! Dyno sheet and pictures **MORE PICTURES*** [Re: 7sec.cuda] #1206036
04/04/12 02:57 PM
04/04/12 02:57 PM
Las Vegas
Las Vegas
Well Mopar has gone to the symetrical port head now so time will tell on that. If the Ford was capable of making another 100hp everyone would run a Ford, just sayin...15HP is this stuff is HUGE let alone 100.
No matter what we can all agree your car certainly runs well. And now with more power hopefully you can harness it all and the ET's will get even lower.
As for the 10,000 RPM thing. I know of a more than a few that are north of 11,000 Rpm in Comp. Hartford's motor is close to yours in cubes and he sees 10,700 pretty regularly. Spent a couple of hours with them at a divisional picking thier brains. Thiers is a Nickens piece with a lot of parts from Arrington car runs 6.60's at over 2000lbs. Hard to believe the performance these Pro Stock guys are abel to obtain ouot of these things for sure.
Re: 5" 650 HEMI! Dyno sheet and pictures **MORE PICTURES*** [Re: camastomcat] #1206037
04/04/12 03:22 PM
04/04/12 03:22 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
The 5inch BS Hemi99 configuration lol.
Adriel Paradise
Substation Design Engineer III
Re: 5" 650 HEMI! Dyno sheet and pictures **MORE PICTURES*** [Re: 7sec.cuda] #1206038
04/04/12 03:25 PM
04/04/12 03:25 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
What about the new spread port Hemi99 engine? Its the latest configuration and I have yet to see it or hear about it outside of the current Pro Stock competitors. I know they didn't change much but I wonder how much HP the new heads were worth.
Adriel Paradise
Re: 5" 650 HEMI! Dyno sheet and pictures **MORE PICTURES*** [Re: Adrielp] #1206039
04/04/12 03:31 PM
04/04/12 03:31 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
So...the Sonny's deal that uses a Mopar/Ford hemi design and a GM type bottom end. Oh, and they have the 5.3 bore center block as well.
Re: 5" 650 HEMI! Dyno sheet and pictures **MORE PICTURES*** [Re: camastomcat] #1206040
04/04/12 03:53 PM
04/04/12 03:53 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
As far as I know, Kaase and the engine builder for Diablo was the only builders messing with the 5inch BS Hemi99 engines. Larry O'Brien(the only dodge Mountain Motor Pro Stock Car) gets all of his parts and help from Kaase then they do the rest. Kaase actually advertises one of the big hemi99 engines while Sonny's does not. The Sonny's semi-hemi was not what I was referring too.
Follow this link: this is the other one I was referring to.
http://www.jonkaaseracingengines.com/pro...dodge-hemi.html
Adriel Paradise
Re: 5" 650 HEMI! Dyno sheet and pictures **MORE PICTURES*** [Re: Adrielp] #1206041
04/04/12 07:02 PM
04/04/12 07:02 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
OK, so the same hemi99 type cyl head, just a different block. Because I thought the one Diablo had built was a 4.900 BS? Or was it?
Either way, these motors are way out of my pay scale. I called Sonny last week and they want $52,800 for a custom 676 Hemi that makes 1380. I'm not saying it's too much or anything, just beyond my wallets reach.
Re: 5" 650 HEMI! Dyno sheet and pictures **MORE PICTURES*** [Re: camastomcat] #1206042
04/05/12 02:31 AM
04/05/12 02:31 AM
Quebec, Canada
Diablo Offline OP
Diablo  Offline OP
Quebec, Canada
My engine was built on the 5 inch bore space platform. We used a 5inch Dovovan block. And I think its true that Goodwin and Kaase were two of very few Engine builders that worked on further developing the 5 inch BS stuff.
In the truck pulling world Money is not a problem for some and a 70-80k engine is something that is bought every second year to keep up with the newer technology.
The NTPA rules state N/A 650ci engine. So the top trucks in the country with the most expensive engines out there are running ALL out 650ci N/A engines. Now truck pulling all out may not be Pro stock all out. A Pulling engine has to last runs of around 20-25 seconds at full rpm. And I do not hear of guys rebuilding their engine mid season or after every run. Just the regular Valve spring maintenance.
Here are the links to the top 3 Pulling engines out there right now. Schmit, Sonny and Goodwin.
Schmit
http://www.steveschmidtracing.com/truck-pulling-engines/new/648-cu-in-bbc-truck-pull-engine
Sonny
http://www.sonnysracingengines.com/truck-pull-engines/sar-649-1575-hp-truck-pull-engine
Goodwin
http://goodwincompetition.com/hemi.htm
Also I have seen 500-550ci X-Pro stock engines be put into Pulling trucks and they just do not work well. They are very peaky engines and once that Skid pan drops and the engine starts to pull down the RPM the smaller Cubed engined drop straight on their face.
There is something called "one run engines" in Pulling. These are the guys that come in with these sick HP numbers for their engines and then you don;t see them at the track for the rest of the year. Usually because something went wrong in the engine and they need the rest of the season to get it back together.
But that one run is usually a pretty darn good show
Re: 5" 650 HEMI! Dyno sheet and pictures **MORE PICTURES*** [Re: Diablo] #1206043
04/05/12 10:35 AM
04/05/12 10:35 AM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
diablo..
you dont have to defend your choice here.. haters are going to hate.. you do what you want, and screw everybody else... you got one bad sumbitch and you seem happy with it ... and that is ALL that matters..
Re: 5" 650 HEMI! Dyno sheet and pictures **MORE PICTURES*** [Re: mcat4321] #1206044
04/05/12 11:57 AM
04/05/12 11:57 AM
Las Vegas
Las Vegas
I cant wait for you to post some video of the thing in the truck. We want to hear it running the making a pull at full song
No doubt at all that these engines are very different from thier drag race bretheren. I woudl hope so as they have different intended uses. You mill makes really good torque and I have no doubt you will do well with it. I think you made the right choice and am looking forward to hearing the results. Good luck this year and go tear em up, or drag them through or whatever it is in the truck pull world
Page 3 of 4 1 2 3 4
