23 spline dana 60 upgrade to 35 spline? #1205326
03/28/12 07:16 PM
03/28/12 07:16 PM
junction city oregon
V
viperblue72 Offline OP
V
I have a 68' b-body dana 60 with powerlock. Is it a direct swap of side gears to install 35 spline axles? Also where is the best place to get the side gears and axles if so?
Re: 23 spline dana 60 upgrade to 35 spline? [Re: viperblue72] #1205327
03/28/12 07:26 PM
03/28/12 07:26 PM
Renton Washington
Triple Threat Offline
Renton Washington
Doctor Diff
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 23 spline dana 60 upgrade to 35 spline? [Re: Triple Threat] #1205328
03/28/12 08:04 PM
03/28/12 08:04 PM
Toronto
mshred Offline
mshred  Offline
Toronto
yes, it should be a direct swap as far as I know...as for the best prices on side gear kits, check out broncograveyard.com. Was referred to me by a member on another forum and they had by far the best prices anywhere I had looked
Re: 23 spline dana 60 upgrade to 35 spline? [Re: mshred] #1205329
03/28/12 08:24 PM
03/28/12 08:24 PM
V
V
Thank you for the info guys
Re: 23 spline dana 60 upgrade to 35 spline? [Re: viperblue72] #1205330
03/29/12 12:24 AM
03/29/12 12:24 AM
I just went through this on a 1969 B body Dana 60, you have to replace the spider gears and the cups they ride in Dr Diff sells a kit for that :thumb I bought that kit and axles as well as his deluxe disc brake kit
Re: 23 spline dana 60 upgrade to 35 spline? [Re: viperblue72] #1205331
03/29/12 02:24 AM
03/29/12 02:24 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
As far as I know, I have the best prices on all the conversion parts.
New 35 spline power-lock side gears with clutch pack $125
New 35 spline B-body axle package with bearings and studs installed $300 pair
Please E-mail me if you are interested.
Re: 23 spline dana 60 upgrade to 35 spline? [Re: DoctorDiff] #1205332
03/29/12 08:43 AM
03/29/12 08:43 AM
an8sec70cuda Offline
I just used Dr. Diff's 35 spline kit in the Dana 60 I built for my dad's road runner.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 23 spline dana 60 upgrade to 35 spline? [Re: viperblue72] #1205333
03/29/12 10:08 AM
03/29/12 10:08 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I've heard of this swap but have a question. Every 35 spline axle I've ever seen is usually an aftermarket axle, and has a much larger diameter than any stock type of 23 spline axle. If you do this swap, can you then, for example, put a 35 spline Moser or other aftermarket axle, that would normally go into a spool, in one of these Power Lok Sure grips, even with the larger diameter of the aftermarket 35 spline axle? If a Power Lok is advertized as a 35 spline unit is it safe to say that the swap has already been done on it?
Re: 23 spline dana 60 upgrade to 35 spline? [Re: Sixpak] #1205334
03/29/12 11:37 AM
03/29/12 11:37 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yep I did the same conversion, 35 spline aftermarket axles/side gears/clutch kit. Cass was very helpful and reasonable on cost.
AFAIK the axles will also fit into a 35 spline spool without a problem, but if you use the spool you have to use green bearings not the oe tapered rollers.
The increased OD of the 35 spline axle is past the splined area...oe 23 spline necks down past the splines, 35 spline aftermarket is about the same thickness all the way down to the wheel flange.
Rich H.
Esse Quam Videri
Re: 23 spline dana 60 upgrade to 35 spline? [Re: DoctorDiff] #1205335
03/29/12 12:32 PM
03/29/12 12:32 PM
Toronto
mshred Offline
mshred  Offline
Toronto
I take that back Cass, those are definitely the best prices. All I remember was at the time I found them cheaper....I stand corrected though
Cass is awesome to deal with! Got my 35 spline axles from him for a great price, and the product was excellent
Re: 23 spline dana 60 upgrade to 35 spline? [Re: mshred] #1205336
03/29/12 12:38 PM
03/29/12 12:38 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I think I was out of the 35 spline internals at the time.
Re: 23 spline dana 60 upgrade to 35 spline? [Re: DoctorDiff] #1205337
03/29/12 12:43 PM
03/29/12 12:43 PM
Toronto
mshred Offline
mshred  Offline
Toronto
possibly...either way, thats a screaming deal! My pops is going to do the 35 spline conversion eventually on his that he's building, so I'll be sure to put him in your direction when he does
Re: 23 spline dana 60 upgrade to 35 spline? [Re: DoctorDiff] #1205338
03/29/12 03:34 PM
03/29/12 03:34 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
67' charger 499 RB 10.57 at 127
Re: 23 spline dana 60 upgrade to 35 spline? [Re: DoctorDiff] #2091387
06/13/16 08:11 PM
06/13/16 08:11 PM
Kentucky, US, louisville
Jb69rr Offline
Jb69rr  Offline
Do you still offer the 23 spline to 35 spline upgrade?
Re: 23 spline dana 60 upgrade to 35 spline? [Re: viperblue72] #2091457
06/13/16 10:44 PM
06/13/16 10:44 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
My question, why? I doubt they'll ever break on the street. Imagine how many of those rears went into all brands of race cars back in the day, with no changes.
Re: 23 spline dana 60 upgrade to 35 spline? [Re: cudaman1969] #2091518
06/14/16 12:38 AM
06/14/16 12:38 AM
mn.
taxidermy man Offline
mn.
I was thinking the same thing, how much power can the 23's take?
Re: 23 spline dana 60 upgrade to 35 spline? [Re: taxidermy man] #2091585
06/14/16 03:10 AM
06/14/16 03:10 AM
Not enough if your making decent power(500+) and the chassis hooks well shruggy I've broke stock axles with less shockGo for the 35 splines while you can still sell your old ones work twocents
Re: 23 spline dana 60 upgrade to 35 spline? [Re: taxidermy man] #2091595
06/14/16 03:38 AM
06/14/16 03:38 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
About 4,500 foot pounds of momentary torque, the 35 spline almost is about 44# more. Somewhere around 6000. That is dump the clutch and sticky tires and break a shaft torque....
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 23 spline dana 60 upgrade to 35 spline? [Re: taxidermy man] #2091934
06/14/16 05:39 PM
06/14/16 05:39 PM
fredericksburg,va
fredericksburg,va
If you're racing a heavy car with 14" tires and dropping the hammer and dead hooking, then by all means go 35, no brainer. All else will suffice. Street car? Waste of money. "If" they brake replace with the 35 stuff. Chrysler did offer large diameter 23 spline axels (short and long) before the aftermarket axel guys got up and running.
