Re: 23 spline dana 60 upgrade to 35 spline?
[Re: DoctorDiff]
#1205332
03/29/12 08:43 AM
03/29/12 08:43 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
As far as I know, I have the best prices on all the conversion parts.
New 35 spline power-lock side gears with clutch pack $125
New 35 spline B-body axle package with bearings and studs installed $300 pair
Please E-mail me if you are interested.
I just used Dr. Diff's 35 spline kit in the Dana 60 I built for my dad's road runner.
[Re: Sixpak]
#1205334
03/29/12 11:37 AM
03/29/12 11:37 AM
Posts: 17,892 S.E. Michigan
ZIPPY
S.E. Michigan
Yep I did the same conversion, 35 spline aftermarket axles/side gears/clutch kit. Cass was very helpful and reasonable on cost.
AFAIK the axles will also fit into a 35 spline spool without a problem, but if you use the spool you have to use green bearings not the oe tapered rollers.
The increased OD of the 35 spline axle is past the splined area...oe 23 spline necks down past the splines, 35 spline aftermarket is about the same thickness all the way down to the wheel flange.
Rich H.
Esse Quam Videri
[Re: DoctorDiff]
#1205335
03/29/12 12:32 PM
03/29/12 12:32 PM
Posts: 3,420 Toronto
mshred
Toronto
I take that back Cass, those are definitely the best prices. All I remember was at the time I found them cheaper....I stand corrected though
Cass is awesome to deal with! Got my 35 spline axles from him for a great price, and the product was excellent
[Re: DoctorDiff]
#1205337
03/29/12 12:43 PM
03/29/12 12:43 PM
mshred
Toronto
I think I was out of the 35 spline internals at the time.
possibly...either way, thats a screaming deal! My pops is going to do the 35 spline conversion eventually on his that he's building, so I'll be sure to put him in your direction when he does
[Re: viperblue72]
#2091457
06/13/16 10:44 PM
06/13/16 10:44 PM
Posts: 8,304 fredericksburg,va
cudaman1969
fredericksburg,va
My question, why? I doubt they'll ever break on the street. Imagine how many of those rears went into all brands of race cars back in the day, with no changes.
[Re: cudaman1969]
#2091518
06/14/16 12:38 AM
06/14/16 12:38 AM
Posts: 49 mn.
taxidermy man
mn.
My question, why? I doubt they'll ever break on the street. Imagine how many of those rears went into all brands of race cars back in the day, with no changes. I was thinking the same thing, how much power can the 23's take?
[Re: taxidermy man]
#2091585
06/14/16 03:10 AM
06/14/16 03:10 AM
Posts: 43,237 Bend,OR USA
Cab_Burge
My question, why? I doubt they'll ever break on the street. Imagine how many of those rears went into all brands of race cars back in the day, with no changes. I was thinking the same thing, how much power can the 23's take? Not enough if your making decent power(500+) and the chassis hooks well I've broke stock axles with less Go for the 35 splines while you can still sell your old ones
[Re: taxidermy man]
#2091595
06/14/16 03:38 AM
06/14/16 03:38 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
About 4,500 foot pounds of momentary torque, the 35 spline almost is about 44# more. Somewhere around 6000. That is dump the clutch and sticky tires and break a shaft torque.... My question, why? I doubt they'll ever break on the street. Imagine how many of those rears went into all brands of race cars back in the day, with no changes. I was thinking the same thing, how much power can the 23's take?
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: taxidermy man]
#2091934
06/14/16 05:39 PM
06/14/16 05:39 PM
cudaman1969
fredericksburg,va
My question, why? I doubt they'll ever break on the street. Imagine how many of those rears went into all brands of race cars back in the day, with no changes. I was thinking the same thing, how much power can the 23's take? If you're racing a heavy car with 14" tires and dropping the hammer and dead hooking, then by all means go 35, no brainer. All else will suffice. Street car? Waste of money. "If" they brake replace with the 35 stuff. Chrysler did offer large diameter 23 spline axels (short and long) before the aftermarket axel guys got up and running.
