Front end alignment... #1204318
03/27/12 12:33 AM
03/27/12 12:33 AM
Closest Race Track
W
WH23H6 Offline OP
WH23H6  Offline OP
W
Closest Race Track
Hey guys,
Just finushed putting all new front end parts in the race car and its time to take it to the front end shop..
I know that there must be some differances in setting up a race car over a street car....what are they?
Its a 65 B body...NSS Car...3200lbs...
Anybody got any hints that I can pass on to my front end guy?
Thanks..
Re: Front end alignment... [Re: WH23H6] #1204319
03/27/12 12:39 AM
03/27/12 12:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
With the front (body) up 1" set the camber to 0
set the caster to as much as you can with toe at 0
to a 1/16 toe in
Re: Front end alignment... [Re: MR_P_BODY] #1204320
03/27/12 12:49 AM
03/27/12 12:49 AM
Closest Race Track
W
WH23H6 Offline OP
WH23H6  Offline OP
W
Closest Race Track
to a 1/16 toe in
So with the desired ride hieght set...lift the front end up an inch? Like maybe front the K-frame?
Re: Front end alignment... [Re: WH23H6] #1204321
03/27/12 01:07 AM
03/27/12 01:07 AM
MR_P_BODY Offline
MR_P_BODY  Offline
to a 1/16 toe in
Yep
Re: Front end alignment... [Re: WH23H6] #1204322
03/27/12 10:22 AM
03/27/12 10:22 AM
gregsdart Offline
gregsdart  Offline
It is good to check toe in/out all the way to the stops after alignment. Your car may ride much higher than one inch under power. It depends on spring rate, and how much air gets under the front.
When ever caster is adjusted, it will affect the toe pattern throughout travel. Adding two degrees caster will lower the outer tie rod about 3/16 inch on a stock front. That is enough to throw the bumpsteer out of whack. The Mopar Chassis manual has an excellent chapter on this, making it easy to understand.
Re: Front end alignment... [Re: gregsdart] #1204323
03/27/12 03:02 PM
03/27/12 03:02 PM
USA
540DUSTER Offline
540DUSTER  Offline
USA
Amen Greg!
Re: Front end alignment... [Re: gregsdart] #1204324
03/27/12 03:16 PM
03/27/12 03:16 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
good luck with the front end guy most do not have a clue, or do not want to take the time. It's nice to have the tools and just do it yourself.
"Just a Bracket car dressed up like a streetcar"
Re: Front end alignment... [Re: MR_P_BODY] #1204325
03/27/12 06:33 PM
03/27/12 06:33 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
With the front up 1" set the camber to 0
to a 1/16 toe in
Just trying to clarify the above 1".
Is this 1" of body lift or 1" of tires off the ground lift? If it is body lift, where/at what point do you usually measure the body lift? Lift at the rocker panel and lift at the K frame are different amounts. Thanks for clearing this up.
Old Geezer Racing
Re: Front end alignment... [Re: SCATPACK 1] #1204326
03/27/12 06:41 PM
03/27/12 06:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use the K-member for that.... I use a bottle jack
on the K and lift it 1"(measured at the K)... that
gives the body 1" of lift in the front to simulate a
down track condition... as Greg said also you SHOULD
do a toe curve to see how bad it is
Re: Front end alignment... [Re: WH23H6] #1204327
03/27/12 06:45 PM
03/27/12 06:45 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Hey guys,
Where are you located?
Thanks..
JAKES AUTOMOTIVE
Re: Front end alignment... [Re: JAKE68] #1204328
03/27/12 07:32 PM
03/27/12 07:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Hey guys,
Thanks..
Gary has done my car a few times in the past... plus
when I get the Rampage done I'll take it to him to
check the front end.... I can get it real close at
home but I still take it to him to check it out
