Re: Front end alignment...
[Re: WH23H6]
#1204319
03/27/12 12:39 AM
03/27/12 12:39 AM
Posts: 52,972 Romeo MI
MR_P_BODY
With the front (body) up 1" set the camber to 0 set the caster to as much as you can with toe at 0 to a 1/16 toe in
[Re: MR_P_BODY]
#1204320
03/27/12 12:49 AM
03/27/12 12:49 AM
Posts: 134 Closest Race Track
WH23H6
Closest Race Track
So with the desired ride hieght set...lift the front end up an inch? Like maybe front the K-frame?
[Re: WH23H6]
#1204321
03/27/12 01:07 AM
03/27/12 01:07 AM
MR_P_BODY
Yep
[Re: WH23H6]
#1204322
03/27/12 10:22 AM
03/27/12 10:22 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
It is good to check toe in/out all the way to the stops after alignment. Your car may ride much higher than one inch under power. It depends on spring rate, and how much air gets under the front. When ever caster is adjusted, it will affect the toe pattern throughout travel. Adding two degrees caster will lower the outer tie rod about 3/16 inch on a stock front. That is enough to throw the bumpsteer out of whack. The Mopar Chassis manual has an excellent chapter on this, making it easy to understand.
[Re: SCATPACK 1]
#1204326
03/27/12 06:41 PM
03/27/12 06:41 PM
MR_P_BODY
I use the K-member for that.... I use a bottle jack on the K and lift it 1"(measured at the K)... that gives the body 1" of lift in the front to simulate a down track condition... as Greg said also you SHOULD do a toe curve to see how bad it is
[Re: JAKE68]
#1204328
03/27/12 07:32 PM
03/27/12 07:32 PM
MR_P_BODY
Hey guys,
Just finushed putting all new front end parts in the race car and its time to take it to the front end shop..
I know that there must be some differances in setting up a race car over a street car....what are they?
Its a 65 B body...NSS Car...3200lbs... Where are you located? Anybody got any hints that I can pass on to my front end guy?
Thanks..
Gary has done my car a few times in the past... plus when I get the Rampage done I'll take it to him to check the front end.... I can get it real close at home but I still take it to him to check it out
