Do I need a High volume oil pump #1201187
03/22/12 12:10 AM
03/22/12 12:10 AM
NY
Beep Beep Offline OP
NY
I am in the process of a 498 stroker build from a 400 block. I am running a street solid roller setup. Do I need a HV pump or is a stock replacement pump good enough? I am using a 6 quart hemi oil pan.
Re: Do I need a High volume oil pump [Re: Beep Beep] #1201188
03/22/12 12:46 AM
03/22/12 12:46 AM
I have three stroker motors like your using, I used the high volume oil pump on all three with the stock 3/8 440-6pak pick up for that pan I did find out if I let the oil level get down to the add mark I would loose some, not all, oil pressure at the end of the quarter mile when I let off and applied the brakes, my car runs 130+ MPH in the quarter, no probblems in the 1/8 mile racing
Re: Do I need a High volume oil pump [Re: Beep Beep] #1201189
03/22/12 11:06 AM
03/22/12 11:06 AM
loose clearances/oiling passage mods/high rpm would be where I'd use a hi vol.
Re: Do I need a High volume oil pump [Re: RapidRobert] #1201190
03/22/12 02:40 PM
03/22/12 02:40 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
not necessarily, the best oil pump is the smallest one that will provide the desired pressure under the operating conditions the engine will see.
Re: Do I need a High volume oil pump [Re: jamesc] #1201191
03/22/12 06:40 PM
03/22/12 06:40 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I tried the HV pump on my 71 RR years ago. I had the same problem of loosing pressure at the top end. Swapped for a HP and never had anymore problems..
I am truckless..
